996 Turbo Forum 1999-2005
water leak
Old 08-15-2018, 07:25 PM
dgw
dgw's Avatar
Default water leak
I have water slowly dripping from under the car. Roughly centered left to right and about under the windshield or a bit toward the back from there. Would this location be condensation from the A/C? Or something else. Its not slick, oily looking or feeling, and doesn't smell. I collected a good sized puddle in the garage after a drive.
I searched the forum but all I saw were posts about coolant leaks.
Dennis
Old 08-15-2018, 07:51 PM
Third-Reef
Third-Reef's Avatar
Sounds like condensate. Look at the coolant in your tank, if it does not look like that you should be good to go
Old 08-15-2018, 07:58 PM
Third-Reef
Third-Reef's Avatar
This is what a coolant leak normally looks like. In my case it was a cherry slurpee spilled in the garbage can
Old 08-15-2018, 09:27 PM
"02996ttx50
"02996ttx50's Avatar
its summer. you're using the a/c. im going with condensation. as suggested, check the expansion tank levels and once you've determined they are normal. faggedaboudit.
Old 08-16-2018, 01:42 AM
PaleAle
PaleAle's Avatar
I check out the "stream" every time I get back in the car. Good thing I've had everything pinned/sealed and it's always water. Still gotta look tho', every time.
Old 08-16-2018, 03:59 PM
2fcknfst
2fcknfst's Avatar
Received 3,933 Likes on 2,988 Posts
Funny... I too have succumb to my fear of leaks when something else in fact leaked there before I got there...
Quick Reply: water leak
