Avant Garde M310 - Bronze
Edit: Problem resolved!
So, new 19” wheels are on and they look awesome. However, my front center caps will not snap in because the axle is sticking a little to far out. Has anyone ever trimmed, or see a really bad reason why trimming, about 1/4” off the end of the exposed axle would be bad? From what I can see, would still leave more than a 1/4” of axle threads before reaching the axle nut.
Looks good. I am most certainly not a tech, however, it does seem like a small spacer would be better plan vs trimming the axle? Not sure if that would work or not. I guess it depends on how much fender clearance you have.
spacers and a suspension adjustment. I would personally never trim anything on the vehicle to make way for wheels. Body components, engine work, brakes sure. Those are a more permanent item on the car. Wheels are subjective, and you may end up hating them after a few months.
Update: I was curious to see where the axle was contacting the centercap so I wet the end with an red sharpie, pushed the centercap right in the middle and it snapped on. Tried other side and same thing happened.
I guess the issue was that I was originally trying to install by pushing around the outside edges.
Bottom line...user error!
you will probably have to measure the size that is on there and then find a sticker to match it and stick it on. you will want to keep the bronze to match, so a same size sticker to perfectly line up is probably only option.
maybe this
http://www.sierramadrecollection.com...al-p18668.html
maybe this
maybe this
maybe this
That looks about right...currently unavailable. I swear like 6 mos ago when I was looking for new caps for my oem turbo wheels, I saw lots of sticker replacement options. Now that I want some...non available!
