996 Turbo Forum 1999-2005
Tire size chart
Old 07-25-2018, 01:29 PM
2fcknfst
2fcknfst's Avatar
Received 4,025 Likes on 3,062 Posts
Originally Posted by emptypockets
Math is not a strength I possess, so to find the percent difference in revs per mile do I divide the larger number by the smaller?
Michelin pilots are what on my car and according to the specs:
245/40/19 = 778rpm
305/30/19= 788rpm......the difference is .98730
I got thisiameter inches (mm)26.72 (678.6)26.2 (665.6)-0.51 (-13) -1.9%Width inches (mm)9.65 (245)12.01 (305)2.36 (60) 24.5%Circum. inches (mm)83.93 (2131.88)82.32 (2091.04)-1.61 (-40.84) -1.9%Sidewall Height inches (mm)3.86 (98)3.6 (91.5)-0.26 (-6.5) -6.6%Revolutions per mile (km)754.89 (469.07)769.64 (478.23)14.74 (9.16) 2%
Old 07-26-2018, 02:38 AM
emptypockets
emptypockets's Avatar
Wow that is just 2fcknmuch and overwhelms my pea sized brain. I get lost on how width can have anything to do with circumference they are two different planes. Until I hear a valid relationship of the two I call an astounding BS! Coming from one who believes he has and idea that performs outside of the laws of physics.
Old 07-26-2018, 04:59 AM
michalik.piotr
michalik.piotr's Avatar
@ghostofpain, not true. had 305's on 19" HRE 540s with nothing more then H&R springs.
Old 07-26-2018, 06:03 AM
ScottKelly911
ScottKelly911's Avatar
Does anyone have a chart that shows tire size in inches so I can pick a combination that will not be in conflict with the AWD function?
What size wheels do you have and what sized tires are on it currently? This would be helpful in having us determine what may be a good setup for you as well as helping you decide what tires may be good choices, as not all tires are available in all sizes. Like the PS4S's that many of us wish came in either 295/30/18 or 315/30/18 sizes so we could use them on our cars with stock sized wheels. Also, give us intended use of the car to also help us figure out what tires may be best suited to your driving, ie, canyons, track or autocross etc. Being in Seattle, I imagine wet traction is a consideration.
Old 07-26-2018, 02:08 PM
2fcknfst
2fcknfst's Avatar
Buddy, slow your roll - I only copied and pasted the info from a tire chart online, here:
https://www.tacomaworld.com/tirecalc...5r19-295-30r19
That's it, it didn't copy over well and makes for easier math. And if you cannot appreciate help, in any form, don't ask.
Old 07-26-2018, 02:34 PM
emptypockets
Sorry the way my post came off it was mostly in jest. I need to use LOL or jk where neeeded.
I will research how width can have an affect on RPM as my pea size brain believes it can't.
Old 07-26-2018, 02:45 PM
emptypockets
2fknfst...I posted the incorrect front tire size should be 225/40/19, using the chart the difference is .5% which is well withing Porsche's specs.
Next is to get the car raised to appropriate height and aligned to see if there will be any rubbing. Not replacing the tires/rims would be a big plus!
Old 07-26-2018, 03:18 PM
NoEardGoat
NoEardGoat's Avatar
Old 07-26-2018, 05:11 PM
emptypockets
Originally Posted by NoEardGoat
Thanks for that chart. I have misstated the front tire size in a couple of posts. Numbers don't lie but if the wrong numbers are used then numbers can't tell the truth. The tires are Michelin pilot sport 225/40/19 F & 305/30/19 rear.
Using this chart https://www.tacomaworld.com/tirecalc I found the ratio between the R&R to be within Porsche's specs.
Old 07-26-2018, 06:15 PM
NoEardGoat
NoEardGoat's Avatar
The problem with your calculator is that it is assuming that all tires of a certain size are the same diameter which they aren't. My #'s in the chart are from the manufacture and are specific for each model. I try to use revolutions per mile because this is the most accurate measurement of a tires diameter. Not all manufactures list the revs per mile so that is when the model specific Tire diameter is used.
Old 07-26-2018, 06:27 PM
Nzo
Nzo's Avatar
Made this for myself a while back, may be helpful to quickly see what sizes will work with others
peritus (05-18-2021)
Old 07-27-2018, 12:03 AM
emptypockets
I looked up the dimensions for the tires on the car and they were what was used in the chart.
Well done and thanks.
Quick Reply: Tire size chart
