996 Turbo Forum 1999-2005
Boost question...
Old Jul 8, 2018 | 03:25 PM
2fcknfst's Avatar
2fcknfst
Originally Posted by pfbz
Not really why folks install higher pressure springs in the wastegates. The N75 frequency valve isn't very complicated, and a failure usually just results in a low boost, easily fixed with a relatively inexpensive part. Defaulting to low boost is IMHO much better than the turbos making too much boost if the ECU is trying to lower it for some reason (pinging?) and can't because the N75 failed and the wastegate spring pressure is much higher than stock.
I suppose theoretically you could run stiff wastegate springs and run the wastegate line to manifold pressure (not vacuum), but that would be leaving TONS of performance on the table and/or eliminating the ecu's ability to tweak boost based on altitude, throttle position, knock sensors, etc..... Sees like really minimal advantage and lots of disadvantage. The tunes out there thee days are great, and the N75 valve is pretty robust and easy to change. If your worried about it failing, maybe just swap in a new one say every time you change spark plugs.
Understood. I appreciate the education.
Old Jul 8, 2018 | 04:18 PM
SamboTT@ByDesign's Avatar
SamboTT@ByDesign
Basic Sponsor
Sambo here haha. Feel free to reach out I think a good education on the 996TT will clear things up and allow you to understand and enjoy your car to it's fullest.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Old Jul 8, 2018 | 06:02 PM
pfbz's Avatar
pfbz
Sambo, please chime in here! Very possible I'm giving incorrect info, but would love to hear from one of our true experts...
Is the description of the N75 valve operation semi-accurate? Reasons why one would put a heavier waste-gate on otherwise stock X50 or non-X50 turbos?
Old Jul 8, 2018 | 06:14 PM
SamboTT@ByDesign
Basic Sponsor
No worries I didn’t go through the entire thread because I’m juggling the kids here. The N75 is the car is factory boost controller. Tables in the ECU mapping give instructions to maintain certain levels of boost. Sometimes you can request more but the wastegate spring is physically too weak to mechanically comply. The reason is because the vacuum line which connects to the actuator is connected to the intake manifold. The factory springs are .6 bar and they can hold up to about 1.1. Beyond that the manifold pressure which is in the loop Forces the actuators to open no matter what you are asking of them the spring just can’t hold up against the manifold pressure. So it is a bit of a safety in itself if you will. When you put a stronger spring in you can set a higher request and if the manifold pressure goes three or 4 pounds higher it won’t force the spring to open mechanically. With proper calibration you’re still fine and safe. These cars do many many things to protect themselves like pull timing, reduce boost, go full rich and even shut the throttlebody. Sorry for any dictation mistakes but hopefully that gives an idea. With the proper calibration we can beef up the hardware a little bit to hold up to more requests made by the tuner. Doesn’t stop at actuators this can go all the way from fueling to the clutch to turbo chargers, intercoolers and so on. You need to hard work to support what you’re asking the court to do. Done safely these motors are capable of up to 800 hp and live a long life. Sometimes you hear different stories but that is all because of the level of aggression taken to the tuning. Of course every car is a little bit different hence custom calibration and it’s benefits.
Hope that helps feel free to reply and just say my name technology will let me know ha ha and I’ll try to reply right away.
Old Jul 8, 2018 | 06:22 PM
pfbz's Avatar
pfbz
Old Jul 8, 2018 | 06:52 PM
2fcknfst's Avatar
2fcknfst
Thank you Sir. I see you are a Cobb Pro Tuner, I will give you a shout this week to discuss mapping options.
Cheers,
Old Jul 8, 2018 | 07:02 PM
RennKit-Dave's Avatar
RennKit-Dave
Former Vendor
Originally Posted by 2fcknfst
So I finally got my erams installed and took the car out on the highway, thanks Dave; spoiler goes up, spoiler goes down - exactly as advertised.
Once again, thanks for the plug!!!
Enjoy the eRam Kit! Let me know if you ever have any questions.
Old Jul 8, 2018 | 07:23 PM
SamboTT@ByDesign
Basic Sponsor
My pleasure anytime. Dave, could you please send me some information on your product? Thanks!
Old Jul 9, 2018 | 02:10 PM
Road King's Avatar
Road King
Who is Sambo...? I too have noticed a slight miss down low and was wondering if this was related to Cobb's tune. Are you still using the Cobb?
I like your wheel choice by the way, they look very good in Anthracite.
Sambo is Sam @ By Design...he did my custom Cobb tune well over 2 years ago. My car runs great, every time, all the time. 1 bar MAFless tune works great with an exhaust and no other mods!
