996 Turbo Forum 1999-2005
997 turbo 6/4 piston yellow caliper install & 350mm coated rotors
Old 04-05-2018 | 06:22 PM
RDS928S's Avatar
RDS928S
Default 997 turbo 6/4 piston yellow caliper install & 350mm coated rotors
Visited my shop today to see what was what.
Big yellow 997 (6/4) piston turbo calipers look great with seal grey.
Old 04-05-2018 | 06:33 PM
Rvca3112's Avatar
Rvca3112
Solid upgrade. Report back on your feedback with them. I plan on doing this soon too.
Old 04-05-2018 | 06:35 PM
mutrksyou's Avatar
mutrksyou
What is the difference between the 997 6 piston brakes and the 6 piston brakes that came on pccb optioned 996’s?
Old 04-05-2018 | 06:49 PM
Nzo's Avatar
Nzo
Looks great, which version are you using, turbo or gt3?
Old 04-05-2018 | 06:54 PM
RDS928S's Avatar
RDS928S
997 turbo version.
Old 04-05-2018 | 06:57 PM
RDS928S's Avatar
RDS928S
see below
Old 04-05-2018 | 07:04 PM
RDS928S's Avatar
RDS928S
I selected Pagid RS-29 pads.
Will do. On report back!
Old 04-05-2018 | 09:45 PM
powdrhound's Avatar
powdrhound
Rear calipers are different. The calipers in this thread are 997TT red calipers but repainted yellow. The 997TT PCCB front calipers are different than the ones in this thread as they use 380 rotors. Lots of other small differences depending on which application the calipers are used for. Generally the GT versions are more desirable as they have OEM Brembo rebuild kits available while the TT versions do not. The 997.2GT/Cup versions also have different size pistons and composite thermal insulators that are lacking on their 997TT cousins.
Yellow looks good with seal grey!
Old 04-06-2018 | 09:54 AM
NoogaSparrow's Avatar
NoogaSparrow
Great info, but to further the question, is there really no functional difference in the fluid plumbing from steel to pccb calipers? I would expect pccb moves less fluid than the steel due to the reduced wear / force needed?
Or am I wrong?
Old 04-06-2018 | 11:05 AM
powdrhound's Avatar
powdrhound
Or am I wrong?
no difference
Quick Reply: 997 turbo 6/4 piston yellow caliper install & 350mm coated rotors
