coolant loss. what to check before thinking "catastrophic" failure
#46
Pinning a leaking fitting is not going to prevent a leak. You either need to buy the new part then pin it, or pull it off use a torch and take the fittings out, clean up both the fitting and the part they are attached to, jb weld them in place then pin them.
