Approximate measurement - New PSS9's
Just finishing a Pss9 install and wanted to see if anybody has an approximate measurements (like how many threads/distance, etc.) just so I can have an approximate set up before putting the tires back on and back on the ground? Just trying to get in the ball park before I take in for alignment, etc at the shop...
Thanks in advance
Thanks in advance
The required height measurement is clearly spelled out in the installation instructions. If I recall, it's a very small adjustment window of about 5-10mm
Why not reach out to Bilstein for the installation manual so you get them on there the way they were designed to be run? I swore someone on here shared the manual before but I can't seem to find it now.
