Headlight restoration nightmare
#46
Most paint has a two cycle cure rate = one for when it's safe to touch/tape/etc - usually 24/48 hours
The 2nd cycle is for hardness - good quality paint usually is fully cured at the end of week 2 - if it's cold out - it can take longer - paint is still soft and can be scratched easily
#47
within a few hours it's ready to sand. Some wait one day, 24 hours. Paint will still be curing for up to 30-60 days after though.
#48
Kudos, that looks amazing.
#49
Yeah, it was more of a "gotta wait til next weekend" thing rather than super-long cure time. BTW, that surface was wicked hard. The P1500 skated over the top.
#51
Yes, after a week it's tougher. It's easy to sand within 24 hrs as the paint is still soft. They really came out great. Should last forever!
#53
Great results! Need to do this, but never done before so pardon the newbie questions.
Sand progressively to 800 or 1k grit, planning to use drill attachments:
or should be done by hand?
Then clearcoat? Planning 2k, better to use primer+clear:
https://www.ebay.com/itm/Spraymax-He...sAAOSw23td0wfw
or straight to clear?
do 2-4 coats?
Then polish with polishing compound?
Thanks.
do 2-4 coats?
Thanks.
#54
https://www.amazon.com/gp/product/B0...ustomerReviews
https://www.amazon.com/gp/product/B0...A1UMBRA5ZTBCX8
do 2-4 coats?
Thanks.
do 2-4 coats?
Thanks.
#55
Thanks!
PPF of any value over refinished headlights? or instead of clear coat?
#56
do 2-4 coats?
Thanks.
do 2-4 coats?
Thanks.
you can see my passenger light on the left was starting to yellow compared to the driver side which was new....
this was the light removed, before sanding...
after sanding...
here is the light prepped for clear... wipe down with alcohol...
this is the orange peel i mentioned earlier...
here is the finished light next to the driver light i compared in the first photo...
let me know if you have any questions...
The following 2 users liked this post by kamlung:
Carlo_Carrera (05-15-2020),
SleepyCyclist (05-15-2020)
#58
Spray it heavier. You can spray this stuff pretty heavy before it runs. It doesn't atomize like a real spray gun, but it's very good. So as you're spraying, stuff in the outer areas will get that texture, so it's best to spray it heavy. It won't run, unless you sit there with it. Orange peel is easily eliminated (if seen once cured) via sanding with 1500-200 (wetsand) and then polishing.
