Intercooler Inlet Scoops for reduced IATs
I recently had a set of intercooler inlets made by Manthey Racing in Germany. I don't get impressed very easily but these inlets are extremelly nice. The inlet lip is fully formed and blends in perfectly with the existing inlets. Aesthetically they hit it out of the ballpark fitting in perfectly with the lines of the car. I did a quick test fit on the car and the fit and finish is nearly perfect with very minor sanding required before these get submitted the the shop for painting body color. The inlets are made out of 100% carbon fiber and are light as a feather at 4 oz each. Attachment will be via 3M double sided tape. Manthey has tested these in their wind tunnel and achieved a speed dependent 5-10ºC (9-18F) reduction in IATs with these inlets. This is a significant reduction. I will be installing these in the offseason.
With that said, I have brand new pair of Joe Toth inlets that I won't need since the Mantheys arrived. If anyone wants to grab these from me, let me know. These inlets also provide significant IAT reduction benefits as verified by several members that are using them.
Manthey Racing CF inlets:
Joe Toth inlets:
Joe Toth inlets:
Have you been able to measure the increase in air volume with either installed?
Take a look at the prototype inlets on the 991GT2RS. They were eerily similar to the Toth inlets while the production versions are less aggressive similar to the Manthey versions.
I have run neither. Several guys here are running the Toth inlets and have positive data on the improvements. They might chime in. I have no reason to doubt Mantheys claims. They have run the inlets on their race GT2s and TTs. Manthey uses a Maha Dyno along with a wind tunnel to verify their parts. There is no bs with Manthey. They are the real deal.
nice stuff, but am not surprised... it is Manthey afterall ...
Toth inlets have gone to a new home...
I need those manthey scoops ASAP! What do they run and what’s the process on ordering them? I went to their site and it’s in German. Had it translated and I could let find anything for ordering.
I had a number of guys email me regarding these with more info. Instead of answering multiple emails, here is the info. Manthey makes these on a request basis. These were developed and used on Manthey's 996TT and GT2 race cars. With that said, getting a set is not exactly easy. Due to company regulations, Manthey will not ship to the US and as such you must have them sent somewhere in the EU and then have them sent on to you. As a result, you will need to pay VAT. All in all, it's a $1400-1500 exercise to get these into your hands, assuming US customs doesn't tag you for some more $. Certainly not cheap but they are top notch..
Just curious... Why did you never run the Toth inlets? And why these now w/o giving the Toth's a run to compare? Who knows - maybe they are even more effective than the Manthey parts...
As I said, just curious.
I just never go a chance to run the Toth parts as I was going to install them this winter but then I managed to get a set of the Manthey ones and decided to go that route. Based on the few guys that I talked to that run the Toth inlets and have logs to back it up, they do absolutely work 100%. I simply prefer the more understated OEM look of the CF Manthey inlets. As far as effectiveness goes, my bet is that the Toth inlets are going to be slightly more effective simply due to their sheer size, but at the expense of picking up more debris and tire marbles at the track.
here is a chart i made a while back showing difference in the toth scoops vs no scoops on same day back to back sessions at a local track. left side is toth, right side is no scoops. i had some traffic in the beginning of the session with no scoops for the first lap or so, and the car was warmer going on track at the beginning of the session with the toth scoops.
i think these manthey scoops look nicer; and yes, toth scoops do require some cleaning out every now and then haha.
^ Thanks.
