Opinions on Suspension - Ohlins, PSS10 or Bilstein Shocks
a benefit of Ohlins is the height adjustment doesn't involve changing the spring preload, ie helper or tender springs are not required and always have full travel regardless of chassis height
Pre-load should never change just by doing a height adjustment. On any coilover. The helpers in coils don't help/hinder travel either. They're main goal is to just keep everything taut when the suspension is unloaded. How have the coils held up over 30k?
preload changes(or doesn't exist) on any coilover where the spring is not in tension when in full droop, a suspension with tender/helpers/no-preload will have less available travel than a coilover with preloaded linear spring/height adjustment cups/sleeves... helpers/tenders change the ride/handling charcteristics vs a linear setup, one not necessarily being better or worse than the other...
They've been good but are overdue for the desired service interval, Ohlins recommends 20k IIRC...
might be able to get close to stock height, the baseline setting is not 'slammed'
Originally Posted by Carlo_Carrera
I think both drop the car almost and inch right off the bat and the Ohlins can go at least another inch lower from there. That isn't enough?
TDAK (12-08-2019)
Ohlins can go lower than that. How much lower I am not sure.
This is my car on Ohlins! Far from lowest setting, and this is IMO the best setting performance wise, looks and that I'll be able to drive the damn thing. Sure, some roads make it a challenge but it's doable and no scrapping...touch wood...
Not sure why someone would need lower than this/GT2 height.
The PSS10's aren't maxed out in that pic, are they?
I'm on PSS10's and my car looks lower than that. I've been very happy with them, but they were on the car when I got it, and I have no basis for comparison.
996dougie (01-22-2024)
What about the KW's? More but worth it? My TT is basically a daily driver. Bought it with Tech Art Springs. Looking for a better ride but with excellent handling.
I talked to bbi autosport about getting these:
KW Clubsport 2-Way Coilover Kit - Porsche 911 (996)
Part #: 35271803
Front Lowering: 0.6" to 1.4"
Your Price: $4,895.99
http://www.kwsuspensions.com/product...-35271803.html
They also suggested - "To properly set up the car, you will need adjustable sway bar end links at the very least: Tarrett Front and Rear Adjustable Sway Bar End Links"
Saw the same set up in a SpeedHunter's article.
Part #: 35271803
I have KW V3's in my Boxster, Ohlins R&T in GT2... very different ideology vs Ohlins...
IMO, KW's are more 'traditional' in their damping characteristics, ie if you had Bilstein Sport shocks way back when (when they built a quality product) it'll be a familiar feeling...the Ohlins deal with damping at a finer level and isolate the small kickbacks/higher compliance
Both are extremely competent, in basic terms- the Ohlins will shock you at the massive speeds carried over all terrain, the KW's give a more kart-like feel
