PSS9 Ride Height
PSS9 Ride Height
Hi,
A freind of mine is having a set of PSS9's installed on his 03 Turbo and is wondering what ride height to have these set to. I know how to find this info in the 993 board and did so prior to installing mine but had little luck searching here.
Any help is appreciated.
Pete
Pete
GT3 player par excellence
if he's careful, you can do GT3 ride height, but you will scrape chin often. 10mm higher than GT3 should be pretty safe on streets (very little rubbing of chin)
Pete...I have mine (RUF PSS-9) set to approx. GT2 heights. You should always check your heights with your corner balance to make sure your weight distribution checks in.
