996 GT2/GT3 Forum 1999-2005
Fender flairs on a 6 GT3?
Old 01-20-2017, 03:37 PM
Yargk
Yargk's Avatar
Originally Posted by cgfen
I'm not a fan of the front bumper cover, but surprisingly, I like the "bolt on" flares.
Here you go then
Old 01-20-2017, 03:48 PM
997rs4.0
997rs4.0's Avatar
Originally Posted by Yargk
Here you go then
Like 👍👍👍
Old 01-20-2017, 05:31 PM
powdrhound
powdrhound's Avatar
Received 1,892 Likes on 1,105 Posts
Originally Posted by AudiOn19s
Getty Design and others offer 1" wider molded front fenders that are basically what you are looking for. Nothing for the rear is going to be easy though.
Flared Fender 2003-2005
$1,079.00 - FRP
$1,559.00 - CF
+ 1″ wider replacement fenders. Direct bolt on for new headlight cars.
Priced per pair.
The RUF stuff pictured above is sourced from Cargraphic I believe. Not subtle but a friend of mine has them on his car and they did allow for 10/12" wheels to fit under the car without issue.
Getty's site is very outdated. They have not offered the wider fenders for about 3 years now. I looked into these a while back and spoke with then about it.
The RUF flare kit is about $4K Euro. It required to the fenders to be cut. FYI, with the proper offsets, you can fit 10" front wheels without issues on the stock fenders. In the rear you can go 12" with the stock fenders also.
Old 01-21-2017, 02:06 PM
rbahr
rbahr's Avatar
Hi Powderhound,
Thanks, what is the section width you have on those 12's, also what is your rear ride height?
I suspect that I have more compliance in the rear than you do so suspension travel is more of a problem with me.
The Ruf setup is nice, but not worth 4K euros to me...
Ray
Old 01-21-2017, 04:46 PM
mistermct
mistermct's Avatar
Here you go then
Now this I like. Didn't think I would but somehow it works.
Old 01-21-2017, 08:48 PM
powdrhound
powdrhound's Avatar
Originally Posted by rbahr
Hi Powderhound,
Ray
I'm running 13s in the rear with 335s. My car is a 996 wide body which is wider in the rear. The front is identical as a 6GT3. I run 10s with 275s up front. My ride height is 102/123.
I just did a set up for a friends 6GT3 with 12s ET61 and 305/35s.
Old 01-21-2017, 11:08 PM
rbahr
rbahr's Avatar
What is a 996 widebody? I have no problem with 305 and even 315's - the suspension seems pushed out a bit because of the new parts I installed - 997R Thrust arms and upper dog legs...
Ray
Old 01-22-2017, 02:51 AM
powdrhound
powdrhound's Avatar
Ray
Any 996 GT2/TT/C4S is considered a wide body. The rear fenders are wider and the rear wheels utilize a 45ish offset thus widening the rear track by about 30mm compared to the 6GT3.
Old 01-22-2017, 07:58 AM
spiller
spiller's Avatar
Personally if I were to do something like this it would be "go hard, or go home" which to me = RSR kit. Speedhunters did a feature on a black 996 GT3 road car whose owner converted to RSR spec, it looked sensational.
Old 01-22-2017, 10:10 AM
Dervish
Dervish's Avatar
^^^^^ Ditto.
Old 01-22-2017, 10:24 AM
rbahr
rbahr's Avatar
Ok, Thanks - didn't realize that. Just looked at the PET and saw the different parts. That would be perfect, and if done properly, be unseen...
I like the RSR setup, my suspension is ~90% RSR, but not prepared to go all in WRT bodywork. Would probably pull the motor and do a refresh 1st.
Ray
Old 01-22-2017, 12:41 PM
powdrhound
powdrhound's Avatar
Ray
The rear end of the wide body cars does make a big difference. I would imagine any good body shop could add the wide body C4S rear quarters, bumber and tail lights. I think a wide body decklid would also be required. It's all OEM parts but I bet it would still hurt the value of the car as they are now becoming collector items. Would be a neat project though..
Old 01-22-2017, 04:03 PM
dave-C2
dave-C2's Avatar
Ray, I Mooty may have experience with flaring/pulling the rear fenders on the 996 GT3. He certainly has owned enough them, including modified track cars.
Old 01-23-2017, 10:10 AM
997rs4.0
997rs4.0's Avatar
Don't start it again Spiller, you are bad influence. All I can think about now is an RSR body kit and a 3.9l sharky engine.
Are you not buying a cup car and moving to the cup forum? 😂😂 lol
Old 01-23-2017, 11:04 AM
NaroEscape
Basic Sponsor
NaroEscape's Avatar
Years ago...a guy here in Charlotte did some body damage to his new (at the time) 6-GT3. He had the body shop put small flares on it - I think the shop said they were actually BMW M3 flares - but they were attached as part of the fenders and painted, not bolt on, so they looked factory. With the car lowered, it looked totally badass. very RSR looking, but somewhat more subtle.
I wish I could find pictures. guys name was Charlie Williams, big exec at Bank of America at the time - retired now I think. I'll try to find photos...
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
  • Data Analysis & Coaching
  • Drivers Gear
  • Crew Gear
  • Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Quick Reply: Fender flairs on a 6 GT3?
