Transmission Fluid- what are you using?
I've been told by a well-respected LSD guy that Mobilube PTX (GT3 fill back in the day) is Delvac + "friction modifiers" = slippery stuff to make Delvac less crunchy in cold climates.
I just say no to Delvac in any flavor and filled with Redline NS.
Might not be the best choice for a track car, but works well for my use.
Craig
I use this Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil - much better shifting than the original Mobil1 and also less LSD chatter in tight turns. Running a Cup differential with new plates and 8:32 final drive. 996.1 box, so no cooler. Custom ratios and steel synchros.
Here's my experience:
delvac in my 964 and 89 G50. A bit 'stiff' when cold but great warm performance. lsd on 89 is a little crunchy. 964 is OK. If that bothers, run PTX or another gear oil with friction modifies.
On my GT3 with guard LSD, with many, many track days, it's been delvac almost exclusively, but i switched to motul 75-140 (on suggestion by my shop from Bill rader) and I've found the performance to be fantastic. I feel it shifts even smoother at high track temps. its a bit better at COLD temps than the delvac too.
yes when I first got it. i can't recall honestly.
I don't think you will see much / any difference in Davis.
My local dealer would sell me PTX last month for $75 a liter!!!!
I've had good luck with Castrol Syntec 75w90 in a few Boxster/911 street cars (no track use, but not to say it can't...), $20CAD a litre and readily available, does well in lab tests vs many others
Personally don't have any issue giving Delvac a few minutes to get warm...by the time engine is temperature ready- the trans is too...
