Misfire Cyl 5
I have a CEL code for Cyl 5 misfire. I will tear into it tonight. What should I be looking for, typically?
I changed spark plugs six months ago to Bosch, I think.
bad ignition coil is my initial bet...
coil is first step
I had a misfire during a trackday and it was cyl 5. Was a fouled plug. Car felt like I lost 80 hp. At thill I usually in the 133-137 mph prior to brake zone at t1- I was doing 114 mph with said issue. Mike
I pulled out the coil on 5 and noticed that the connector was very loose. There was no visible crack or damage. Resistance measured 0.8 ohm across the two outer pins, similar to number 6 coil. So, I swapped 5 and 6 coils just for the hell of it, pushed down on the connectors tightly, and cleared the CEL. Fired it up, seems to run well, but I did not drive it. I should have looked at the plug too.
It is a 996 GT3
It is a 996 GT3
Nice
