Any ideas on how to remove the yellow puck from the piston without damaging the piston? I tried liquid wrench but no luck. It does have a lip to grab and I tried to use a needle nose pliers but it would not budge. I don't really have a good vice to hold the piston steady.
By the way it was a bitch to get all 6 pistons out of the caliper...... Not to mention the mess the fluid makes.
There was a thread recently here. See below. You probably have to buy new pistons and pucks, they're are connected. There is no known source for puck replacement only. I know this does not directly answer your question, but thought I'd share what I know as I will be doing this soon.
I have some extra replacements so in this case that is not the issue. I was just trying to figure out a way to get the broken one out so I can put in a replacement. Worst case scenario is I would use the broken one as is. The main thing is a level surface so the pads wear more evenly.
Any thoughts on how to remove the old puck from the piston? I tried a vise and used a soft rubber to protest the piston. However, even in a vice since the piston is round it was moving then I put on a lot of pressure to remove the puck. I don't want to mess up the piston and have to purchase after market ones. I can put in back as is. It has been broken at least for 3-4 track seasons and minimal effect -- just the pads don't wear evenly.
Maybe some special penetrating oil? or another process to loosen? Note, I do have replacement pucks -- just need to get the old pucks out of 2 pistons out of 20.
Stick the piston/puck combo in your oven at home. Heat it up to 400F and then try to remove the puck. The metal piston will expand more than the zircon puck and the puck should come out...
Hi powdrhound, that is what I was looking for! Bake at 400F for a feww minutes and monitor. Of course, it will have to try this when my wife is not in the kitchen otherwise, I will get a lot of grief for putting a car part on her baking sheet.
Well, the baking did the trick!!!
I did the smaller piston first at 400 degrees for around 3 minutes. The puck just came off with little force. I tried the same thing for the largest puck and it did not work so I put it back in the oven for 5 more minutes and same off like the other one with little force.
So, tomorrow I will put them into the caliper with the new yellow pucks.
I was going to suggest heat as this is what causes them to separate.
Get these 997.352.086.91 you will need 1 per piston, this is a motorsport part (any shop with a motorsport account can get them), puck holder clip see post 26: https://rennlist.com/forums/997-gt2-...ml#post9450471
After the pucks have been in for a long time it can be difficult to keep them in without falling out. The newer ones seem to snap in better. For a few of the old ones I used glue so they would not fall out during installation.
Some of the old ones are had a solid seal like the broken ones I could not pry out.
In the attached picture 2 were glued in (to replace the broken ones) and 3 snapped in and seemed to be firmly in place. One was in the caliper before and it was securely attached.
