FS: Brand NEW OEM 996GT2/GT3/TT rear brake cooling ducts
I have a brand new pair of OEM 996GT2 rear brake ducts. They are still in factory packaging as seen below. These are a direct bolt on to the 996TT/GT3 and a must for tracked cars. These will fit many other 996 cars as well. Those simply clip on to the rear lower control arms via the included metal brackets and plastic push rivets. Part number on the left kit is 996.331.127.90 and the right one 996.331.128.90 I have these for $150 for the pair.
I also have an identical used pair available including mounting hardware (visible in the top of the picture below). They are in good condition with the left duct having a small 1/2" crack in the lower scoop. It does not affect functionality but it could be stop drilled and glued. I have these for $90 for the pair.
Shipping is $15 per pair, CONUS. Buyer responsible for paypal fees.
[url=https://flic.kr/p/oPtiBv]
[url=https://flic.kr/p/oPs88M]
[url=https://flic.kr/p/oPu2DK]
1/2" crack close up in right used duct
[url=https://flic.kr/p/oPtgnk]
How much are they new for a pair?!
I still have PCCB on the back. I hope the scoop won't divert debris to the rotors (like tire rubber, small rocks, etc.) But I am guessing it is probably fine since it was meant for GT2 and GT2 all came w/ PCCB as standard.
They are around $90-95 each at the dealer.. I just switched to the 997.2RS ducts so these were just collecting dust...
Here is a picture of the 7.2RS duct and the portion of the heat shield that needs to be trimmed away.
[url=https://flic.kr/p/p4vRKB]
Here is a shot of the 7.2RS ducts from the rear. You can see the mounting brackets that attache the duct to the LCA.
[url=https://flic.kr/p/oMH2A5]
Here is a picture of the 7GT3 air guides and the NACA duct exit from the belly pan
[url=https://flic.kr/p/p5c3WM]
