Rain & no glass in doors for gutted car
Looking at supporting at bottom. To remove loosen support unbolt and slide out entire polycarbonate window. To close the door just tuck top into rubber guides. This is what shop explained to me. I have seen others with enclosed trailer with simple hole in two places at bottom of window with bolt that sits on bottom rubber rail. This is ok for at the track but I need something to hold in place when open trailering. Hope this makes sense.
Steve
Steve
OK now.. step by step.
Tell me where I'm wrong;
- Door open.
- partially Slide in plexi window into door.
- install support on inside resting on door so plexi doesn't fall down into door cavity.
- Shut door.
- press top edge of window into rubber guides along a-pillar and roof.
- Lock door.
Is this it?
Yes. Except before shutting door need to slightly bend window to fit into a-pillar and top seal since window does not slide down prior to closing. To not allow window to be lifted out I will secure window with threaded ***** from inside. This is initial thoughts.
Steve
Steve
