New splitter for 996 GT3
Hi folks,
I'm working on another new splitter for 996 GT3 and would appreciate some input. What I am doing is making a two piece splitter, one section will attach to the car in the standard way the cup and my splitter does now. The second piece with the splitter blade will the attach to what I will call the base. The attachment will be with either dzus or the plastic fasteners used currently to install the splitter to the bumper.
The plan is to have the splitter drop down 1-1/2" to 2" from the bottom of the bumper at the center front, less at the sides as this portion of the bumper is lower. This drop will also be adjustable in how much the splitter can be lowered. This would give a degree of custom fit for vehicles with different ride hieghts. Currently I have the blade portion of the splitter extending out 3-1/2" at the front and 2" at the sides.
The picture might provide a better idea of what I am working on. The flanges for the drop are excessivley large at the moment as I need excess for trimming. Please keep in mind this is a pattern in the early stages of development. A lot of excess material still needs to be trimmed off.
Any thoughts on dimensions for the blade and the amount of drop from the bumper would be helpful. Thanks in advance for your input.
Thank-you for doing this Joe.
I look forward to offering you my patronage as I am currently building track only stripper.
Assuming that most customers for something like this already have a lowered car...
Anything lower than a cup splitter makes it a hassle to load onto a trailer even with longer ramps. The blade would have to be very easily demountable at the risk of making car prep a bigger hassle than it is worth.
That is why the splitter portion will be easily removable. The portion remaining on the car will only be about an inch down. the detachable splitter will then be as low as you require. I think six very easy and quick fasteners will make the install simple. You can get the car on a trailer and then run a splitter as low as you want.
Would someone be so kind as to put a tape measure to their car at the center of the front bumper. Please let me know if the blade at 3-1/2" would extend too far forward. Thank you
I think that 2" forward of a rubber cup splitter would be fine/enough. But that is not in relationship to the bumper itself, if that is what you mean.
One thing to consider is the mounting to the tub/structure. With the additional leverage, it has to be strong.
I am all about an option like this. My car is at 102mm ride height in the front and I have already destroyed one of your splitters and am well on my way to destroying the second. I can just make it on to my trailer now since I have some long ramps but a "removable" splitter with would be so nice for making it into one of my garages that I can't even attempt to get into now. My suggestion would be Dzus or similar attachment mechanism over the factory plastic rivets as I just don't think they are strong enough. I have been contemplating putting nutserts into my bumper so I can use "thumb bolts" to install my current splitter (ie your fiberglass one). That way I could just reach under and unscrew it relatively easily / quickly.
Boostin, That's good for me I can sell replacement splitters (kidding). That's the reason I am working on this piece so it will make it easier and less problems or damage.
Joe, use Dzus fasteners please
My Car is at home now so if you need me to take any additional measurements let me know.
Cavlino, Please take a look and measure if 3-1/2" for the splitter blade width would extend too far forward. Yes probably dzus but the plastic rivets would be an option for apppearance (all black) to match the finish.
/Carm
