Question about Tequipement Harness Bar Install??
Peter
Alex, Brafasco can probably get you the hardware that you need. There are a few locations near you http://www.brafasco.com/locations.asp#on
You can drop by the house if you want to check out my installation. It's standard, but might help get you lined up.
Thanks Francois... I will do that.
BTW, Sorry for the dumb question but I don't have the hardware at hand...
What length bolts do I need and how far do I need to thread them?
Thanks.
Thanks.
I was able to pull the carpet back enough without removing all of the trim Pieces and dermal out the necessary plastic. I also ditched the lower bolt and replaced it with a Gr 8 7/16 sae thread stud. I made the stud by using a bolt, cutting off the head and threading both ends. By doing this I didn't have the alignment problem with the lower bolt and worry about stripping out the seat belt anchor threads. I used Blue loctite on the inner thread to anchor the stud to the car.
Peter
Peter
I needed to remove the passenger seat which meant removing the drivers side seatbelt anchor bolt.
I knew when it came out that it wasn't going back in without a struggle.
I did a search, found this thread and took the same path that Peter did.
I just installed one stud for now.
Photo's below
I started with a 4" bolt and created the stud as required.
Luckily I already had the correct die, so this DIY cost me about $3.50 for a grade 8 bolt and nut.
Those of us lucky enough to live in San Diego or SLC, Utah have access to a wonderful industrial hardware store where you can buy one of most any fastener you might need.
http://www.marshallshardware.com/
You can buy the same fasteners from McMaster or Grainger, but Marshalls doesn't make you buy the entire box.
I too used Blue Loctite on the threads.
Basic Sponsor
Great idea, looks super clean too!
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
