How does rear caster affect handling
Hi, I'm in the middle of a minor refresh of my car all around and have got some rss suspension mounts. My query is about the adjustable castor pucks on the rear suspension. How is this best set? I was told by one guy to set it to what is basically maximum caster as in the picture below
Attachment 721059
Does anyone have any experience of setting up the rear suspension with this kind of puck set up and how does running it like in the photo affect how the car rides both on track and street?
Any help would be greatly appreciated
Neil
Attachment 721059
Neil
Well, caster is only applicable to a steered wheel - so a front wheel in the case of traditional cars. Your attachment is not working (at least for me) so I am at a loss as to what you are asking about. Can you clarify?
Cheers
Cheers
Attachment 721059
Neil
Attachment 721059
Neil
changing the rear caster angle must surely have effect on anti-squat geometry
OK, now that I can see what you are looking at... As I originally stated caster is normally associated with a steering axle, but here you are talking about changing the suspension pivot axis relative to a vertical axis - so largely the same thing. Based on what I know of front caster changing the rear caster will affect the dynamic camber and possibly toe.
That being said I have no idea for settings. Does RSS have any recommendations or do you have a race shop you are working with?
Cheers
Cheers
Hi, thanks for your reply. The supplier whom I got the rss parts informed me that that's the way he fits these when he does it. He said it aids stability but I just wanted opinions of anyone who has fitted these and how they set them upa nd how it works for them.
My main worry is how it affects changes to camber and toe as the suspension travels, and whether its a benefit or not for track work(my main use of the car for the future).
I will be setting the alignment myself with help,at a local shop with a hunter system.
Cheers
Cheers
