Wider front fenders?
Does anyone know if there is a good quality front fender available for the 996 GT3 that will allow you to run a wider front tire ?I would love it if PMNA had such a part available although I am sure it will cost the equivalent of the national debt of Cyprus!Alternatively any suggestions about fitting say a 265 front to the car as it sits ?Thanks in advance HOM
Might not be what you are looking for as you are looking for the complete fender, not the "extension".. but this let you widen your front track about 1" on each side..
http://www.cargraphicts.com/index.php?id=128883&L=1
Click on the "Extension Kit"
Basically, the bolt-on / rivet-on style from the 993GT2..
I've heard their fit and finish is one of the best in the industry aside from Porsche (obviously) and DP. It's fiberglass so it will need a little bit of work but I bet they can look good.
GT3 player par excellence
how wide you want to run?
i was able to run 9" with oem fenders
if you roll fender a bit, you can run 9.5
Rolling fenders
Actually rolling sounds better to me!What kind of skills are needed to do the rolling properly ?I mean can any body shop do it?
Why does it have to be so complicated?
Just becareful. Use a heatgun or blow dryer to warm up the paint around it or the paint can crack. At least that's what I've read online...
