996 GT3 cup LWFW, coolant fix, and other updates to my GT3 that I'm excited about..
So after reading countless threads on the dreaded coolant issue, and watching videos of what happens when the glue fails, I decided to take the plunge and take care of the coolant issue before it takes care of me - especially since my car is a street/hwy car, I'd hate to endanger anyone else, or myself! There isn't much run off on the street.
The stats:
2004 996 GT3, with about 25k miles on it, never tracked, always babied, fully maintained with receipt trail, and stamps in the books.
The mods:
RS wing, RS seats, JoeT front lip spoiler, and a couple other small bits and pieces. The car has a bunch of exclusive options from the factory.
The plan:
I'm going with the Sharkwerks method of bolting/riveting the fittings, and I can't wait to see the end result!
But, since the motor is going to be dropped, and consequently I'll get new coolant, and coolant hoses, I thought it would be a good idea to throw in a couple new parts while I'm there.
What I ordered, and received, and took photos of:
I went for the RS pulley, new belt, new shifting fork, and shaft, Cup Flywheel (the 8.2lbs one), new clutch, pressure plate, guide, ring gear, bearing, all bolts, etc, and a new airfilter (lol). Basically anything in the clutch mechanism that is generally hard to get to, I'm replacing.
I have no idea what to expect from the car after this. There is very little info on LWFW's (especially the cup version), most people say that it's not really worth it, but it's only a little bit extra money. I've read 911SLOW's posts about LWFW's and from what I've read, it seems to be a decent upgrade.. I hope!
The car should be done in the next couple of days, and I'll post my opinion then.
Any comments on what I should be expecting with this 8.2lbs flywheel?
The stats:
The mods:
The plan:
I went from stock to RS LWFW a couple if months ago. I thought the difference was quite noticeable. The car revs so much more freely. Heal and toe is harder as te revs flair much quicker when you blip the throttle. It also feels much zipper through the gears.
The added noise when out of gear and foot off the clutch adds to the drama of the car. The chatter from the gearbox giving it that real Cup car feel.
Are you not replacing the Diff at the same time? I decided not to do this while the clutch was being done, but now wish I had. My diff needs replacing now and that means more labour hours than if I had it done when then clutch was being done.
super mod, 1st, 2nd unreral improvement. If you have the funds replace the dif with a Guards at the same time. You will be doing it soon unless it already in there. Have fun
Looking forward to hear your impressions.
Thanks for the replies guys, I'll update with the progress.
Another thing I'm doing, is changing the fuel filter too since I'm at it.
And I just changed the plugs and coils too. The car is going to be so mint after. I can't wait. It might be ready sometime tomorrow!
I'm not too bad mechanically, but this is a little above me, so a shop is handling it all for me. It will be done correctly by a master tech.
If only I could do this stuff myself, I'd have used the labor money for so many things.. diff,.. wheels, spacers, tires....
I'll post pics as I get them!
Car is done!
Here's the full list:
- Air filter
- Fuel filter
- Motul + oil filter
- Coolant
- Plugs
- Coils
- Cup Flywheel (8.2 lbs)
- Clutch+Pressure plate
- Slave Cylinder
- Clutch fork + shaft + bearings
- O rings everywhere
- RS Pulley
- Belt
- Tapped and bolted down all the coolant fittings
- Corner balanced to the exact same Front L&R
- Rears within .01'
Holy does the car feel completely different, in every way. Jaw dropping.
The cup flywheel is the best. Not difficult to drive, chatter is there, but it's not bad at all, and adds to the drama of the car.
After years and years of ownership of this beautiful machine, I have fell in love with it all over again.
If anyone is hesitating doing the 8.2lbs flywheel, afraid of it being difficult to drive, don't. It's easy, just like stock, but revs quicker, stops faster.
Wow.
- Air filter
- Fuel filter
- Coolant
- Plugs
- Coils
- Slave Cylinder
- RS Pulley
- Belt
- Rears within .01'
Wow.
Its terrific to hear that it exceeded your expectations. Thanks for the update.
