Battery tender usage
I have an Odyssey and use the clips directly on the battery. I just run the cord up between the body panels so it comes out right at the bottom of the windshield on the drivers side and then shut the hood. Not the best explanation since I doesn't go through any body panels but there is a little panel gap between the top of the fender and the windshield wiper cowl (if I remember correctly) which then allows you to shut the hood without closing the wire in it. Hopefully that makes a little sense ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
