Will a K24 GT2 Turbo work on a 02 996 Turbo?
If so, will it be a direct fit?
What would be the HP gain on the stock 996 TT?
Will I require an ECU flash to make it work properly?
Thanks for your input.
Regards,
Mike
Regards,
Mike
using k24 turbos is the same as a x50 tt. you need a tune and some add the gt2 or 997.2 intercoolers. if your going to use k24 may as well rebuild them with billet wheels and bigger covers.
I would check with a qualified local shop or GMG. Yes it can be done but it's not a bolt on solution for your home garage based on the question. If you are changing them you do need to look at new IC. I may have a set of GT2 ones in the garage.
should be bolt-on and function fine as-is without any extra parts/tuning, will be more laggy and shouldn't see any addtional power without tuning, there is a chance the factory k16 tune won't like the 'boost curve' of the k24's and go into a safe mode
If looking for more top-end power, I'd go for it and call Kevin at UMW for a tune
Hey Mike,
No worries, I'm in Brantford but have extended family in St.Cats/Niagara.
Kevin is here on Rennlist,just search the 996 Turbo area with 'UMW' and more info will come up...
https://rennlist.com/forums/996-turb...-975-00-a.html
his website is http://www.ultimatemotorwerks.com/index.html and is in Washington state
