Exhaust Options (mufflers)???
#47
48k miles and have had 2 cats go bad.
#53
Basic Sponsor
My car is primarily used as a daily driver and since my ownership and 15K Miles I had a set go bad, here in FL no smog = easy fix + ECU flash to get rid of the light.
#55
So if you remove the internal parts of the cat:
1) you can get the CEL light to go off and stay off?
2) any difference with sound or performance?
#56
Fabspeed o2 spacer would eliminate without a tune. See pic below.
Probably a little, but I wouldn't go out of my way to do it.
![](https://www.fabspeed.com/images/spacer_90degree.jpg)
#57
Basic Sponsor
Durametric will reset it, it will come back every other week or so. I had EPL reflash the car and delete the Rear 02 CEL light and do a performance tune at the same time. The tune makes a slight difference, but the real benefit is no more CEL lights.
Slightly louder, but not obnoxious by any means, no drone (Europipe setup now with the cats gutted).
#58
#59
Which Europipe do you have - street or track version? I've got the street version, and haven't had any issues with the cats so far. Did you gut them in response to a failure, or just for better flow? And did you need to replace the empty can with a straight pipe? Once before on a previous car I gutted a cat and got an irritating ringing sound at certain RPM's, caused by turbulence inside the empty can. It went away by straight-piping the can.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Peter
