Throttle Pedal
I just prefer the simplicity of the GSR pedal. I'm sure the Rennline quality is excellent, as always, but I prefer simplicity in build and look.
I do like the GSR's pedal itself better (smooth surface), but I guess it retains the original box's plastic hinge. I have not had problem with mine so I haven't had a chance to look at the area yet, but I guess Rennline's unit replaces the hinge completely. So to be, that's a difference in design. I don't know whether that's needed or not, however.
I know what you are saying, but can't comment since I haven't taken mine apart yet. I 'assume' that the pedal is all that's needed to make the system indestructible
I do know that when I put my foot down in anger, I feel a bit of rocking in the pedal, so if it breaks before I replace it, I'll be ready. Apparently a 30-minute job.
Installed the GSR pedal today and it's very simple. Also put on the SRP covers while in there. They had been on my desk for 2 years after all.
Looking at the OEM part, it's obvious that the weak link is the pedal-side hinge, the light plastic rings that break off (mine were fine). The part of the hinge that stays with the original assembly is a plastic shaft that is strong enough not to break (top right in the picture).
Therefore, there is no need to replace the whole assembly a-la-Rennline, just doing GSR pedal is sufficient to ensure many years of flat-out bliss.
As you can see on the picture below, the hinge part of the gas pedal does separate from the pedal, and there is a part number stamped on it. Not sure if this part can be ordered, but if it can, it would be a nice spare to have, just in case. PN is 996 423 193 01
Will have to order one in the near future for sure.. ! Thanks for the feedback!
A quick question when setting the stop on the pedal, though. How do you know if that's enough travel for 100% throttle? (Since it is all done electronically now..)
I have been very happy with the GSR pedal. Installation was simple and no more side to side wiggle. The smooth surface is not an issue. If I had any issue it would be getting use to the wider width. When braking hard, my foot needs to be over more so I do not accidentally press the gas pedal. Noticed this when down shifting heal/toe. Great product!
Steve
Steve
By "looks ok" I mean that when pushing the pedal all the way in against the stop, it looks as though the push rod is bottomed out.
I wonder if there's a way to get the throttle position read out when using Durametric or dealer software. Or maybe the ECU is setup so that the last few travel on the potentiometer is treated the same as full throttle, to prevent this type of situation.
