Coolant Hose Part Number? Best Place to order them from?
Looking for the part number on the single long hose that comes off the bottom of the expansion chamber and snakes around under the engine. I have been all through the diagrams and can't find the piece I am looking for~ Been on Pelican Parts, ECS Tuning, and Auto Atlanta....
Thanks!
Ian
Thanks!
Ian
Unfortunately its not there. I have been looking at diagrams including that one for hours~ I guess I am going to have to drain the coolant and pull it off and hopefully find a part number.
#23 from illustration 105-00
You can see it in the other posts here on Rennlist, but you have to scroll to the next page for the part number which is omitted from all of the posts here. I replaced that one and the two main hoses in the engine bay when I had my fittings welded.
Tip...if you take the clips completely off the main hoses in the engine bay make sure you mark where they go, one of them is slighly different from the others and it's impossible to tell unless you look really closely. I kept having one of my main hoses blow off after I put everything back together and it took me days until I figured out the stupid clips were slightly different. Thankfully another Rennlister helped me out with that so I"m passing it along too.
Replaced the coolant hose but it is leaking around the clamp where it mates to the bottom of the engine. Is there a specific way to prep the hose prior to reinstalling it other than just cleaning and drying it thoroughly?
I changed the hose and when the engine got hot it was still leaking coolant around the clamp. Hoping cleaning and drying it will solve the problem.
Thoughts?
Thoughts?
