View Poll Results: What's your preference in Steel Brake Discs for Track use on your GT2/3?
SpeedArt
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
![](https://rennlist.com/forums/clear.gif)
0
0%
Voters: 87. You may not vote on this poll
The 2012 GT2/3 Steel Brake Disc Track Survey
#151
My guess would be (1)not a PFC hat unless it was stressed really hard to turn that color...and even then I'm not sure it would. (2)that user error could have lead to that..meaning the the hardware wasn't torqued properly and then once it moved within the hat, the integrity was compromised. Other than that, not sure what to say. Of course, this is purely my opinion based on a picture.
#152
well this is what happened to my first set of PFC .. gonna stick with the Giro's going forward!
I can't really complain though as these were on their last legs although wear markers still have 25% left.
Anyone ever seen this type of failure before?? Gladly felt a subtle but clear lack of braking ability and picked up a new/squeaky noise
so came in .... only to find this today.
The hats may be the wrong ones, not matching the pads..
I'm also surprised as they featured so well in the survey and in user comments.
I'm assured they were black when bought and added to the car by PO ...
turned gold through heat ... used for 2 years about monthly for 30-40min a month in sprint races
ie 2x10x2 = 40 10 lap races on a 2005 996 Cup
The dual nut/bolt on the hat doesn't look like other pics I have of PFC so I'm not
100% sure myself but PO is very experienced guy so I doubt he remembered wrong ..
but I was more keen on finding out if anyone has even seen this kind of failure
as I haven't seen/read about anything like it .. anyways, thanks for the comments
They look worse than any rotor I ever threw out..
#153
Still not convinced that a black annodized aluminum would turn gold from heat. Purple has been observed a lot in black annodized wheels, but not gold.
I would be surprised if those are factory PFC hats.
#155
What a sec, I think I totally missed the obvious. Are those Pagid19/29 pads (yellow)??? If so, they will NOT fit using the PFC 2-piece setup and will make contact with the hat hardware. That very well may be the source of the problem. Pad wears down, solid plate make contact with hardware, and KABLAMO!
#156
What a sec, I think I totally missed the obvious. Are those PFC19/29 pads (yellow)??? If so, they will NOT fit using the PFC 2-piece setup and will make contact with the hat hardware. That very well may be the source of the problem. Pad wears down, solid plate make contact with hardware, and KABLAMO!
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
But you probably meant Pagid pads.
#158
yes they are pagid yellows - pads arent that worn down - but may have happened on previous set
.. will check that out thanks Dell, Frank, ìP
#159
Does anyone have experience with running Alcon 362mm fronts and PF08 pads?
#160
Basic Sponsor
Still the best in my opinion... Ive seen over 50 track days on these and still looked OK, but replaced because of basic maintenance and cost.. $ for $ the best buy..
![](https://rennlist.com/forums/members/rick-deman-albums-deman-rotors-picture24927-rotorssilver.jpg)
![](https://rennlist.com/forums/members/rick-deman-albums-deman-rotors-picture24928-rotors.jpg)
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
#162
Discs were ordered ... one hat went missing so they re-used the old hat on this (broken) side.
By my rough calcs that means the hats were 3-4 yrs (40-50 sprints) old. And seen pics - they were black before ... so heat will turn them gold and kill the anodising it seems ... eventually.
So I must apologise for anyone being scared/scarred re my comments on PFC.
I've been very happy/successful with the rotors ... just need a new set of hats!!
