Basic maintenance of 6GT3 for Beginners
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Although you may already know, i post the topics of easy DIY.
996 GT3 Jack up 1
996 GT3 Jack up 2
Changing front brake rotor 1
Changing front brake rotor 2
Changing rear brake rotor
-Making a dummy plug of brake pad sensor
-Porsche Caliper Screw
-Porsche Brake Pad Damper
-Porsche Brake Rotor Securing Screw
-brembo Type III Direct Replacement 2-Piece Floating Discs FRONT
-brembo Type III Direct Replacement 2-Piece Floating Discs REAR
-Brembo Type III 2-Piece Floating Discs detail
Changing brake fluid
-Ate TYP200
-Motive Products POWER BLEEDER Adapter Kit Model 1100
-Motive Products POWER BLEEDER Model 0101
Screw plug and sealing ring for oil change
Changing engine oil and filter
-Porsche Oil Filter Wrench
-Porsche Oil Filter Kit
-Oil Filter Comparison
-Porsche O-Ring
-Porsche Oil Filter Housing Cover
-Porsche Screw plug (M 20 X 1.5)
-Fischer & Plath Copper Washer (20 X 24 X 1.5 mm)
-Porsche Oil Drain Plug
-Mobil Mobil1 0W-40
-Mobil Mobil1 kinematic viscosity
Changing transmission oil 1
Changing transmission oil 2
-Short neck hex wrench for changing transmission oil
-Porsche Transmission Magnetic Drain Plug
-Fischer & Plath Oil Drain Plug Seal (22 X 27mm)
-RED LINE 75W-90NS
-RED LINE DIFFERENTIAL FRICTION MODIFIER & BREAK-IN ADDITIVE (If need)
-RED LINE 75W-90NS kinematic viscosity
Changin Air Filter
-Porsche Air Filter
-Air Filter Comparison
Changing the drive belt
-Contitech Serpentine Belt
Changing the cabin air filter
-MANN+HUMMEL Cabin Air filter
Changing the 997 Gearshift bracket 0
Changing the 997 Gearshift bracket 1
Changing the 997 Gearshift bracket 2
Changing the 997 Gearshift bracket 3
-Porsche Gearshift bracket for 997
-996 vs 997 Gearshift bracket
Installing the SCHROTH Profi II-6H 1
Installing the SCHROTH Profi II-6H 2
Installing the SCHROTH Profi II-6H 3
-Profi II-6H SlipStop VS Profi II-6H Porsche GT3
-The buckle detach tool
Installing the Air duct for transmission
-Air duct for transmission
-Speed Nut
-Tapping screw
-Spacer Sleeve
Installing the Spoiler control arm (R)
Installing the Spoiler control arm (L)
-Spoiler control arm
Installing the Ram Air Scoop
I will update this colum when the new DIY topics will be completed.![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
996 GT3 Parts
996 GT3 Jack up 1
996 GT3 Jack up 2
-Ate TYP200
-Porsche O-Ring
-Mobil Mobil1 0W-40
-RED LINE 75W-90NS
Changin Air Filter
-Porsche Air Filter
-Speed Nut
-Tapping screw
-Spacer Sleeve
996 GT3 Parts
Gr8 stuff Sam - nice update!
Have you ever done the rsr crankcase breather re-fit? If so, did you drop engine to do so or by removing plenum and going in from the top?
Breather link
Breather link
Add changing my oil pressure switch.
Use these pictures.
Note that the GT3RS version is fitted horizontally to the end of a metal tube with a bracket and it is much easier to fit a standard 0.75 inch spanner on it.
http://www.flickr.com/photos/83374345@N00/7261235864/http://www.flickr.com/photos/83374345@N00/7261235864/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237106/http://www.flickr.com/photos/83374345@N00/7261237106/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261236290/http://www.flickr.com/photos/83374345@N00/7261236290/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237862/http://www.flickr.com/photos/83374345@N00/7261237862/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261238262/http://www.flickr.com/photos/83374345@N00/7261238262/ by http://www.flickr.com/people/83374345@N00/, on Flickr
At tick over
http://www.flickr.com/photos/83374345@N00/7261558004/http://www.flickr.com/photos/83374345@N00/7261558004/ by http://www.flickr.com/people/83374345@N00/, on Flickr
at 3000rpm
http://www.flickr.com/photos/83374345@N00/7261558794/http://www.flickr.com/photos/83374345@N00/7261558794/ by http://www.flickr.com/people/83374345@N00/, on Flickr
Use these pictures.
At tick over
at 3000rpm
