305 rear tire?
It seems people are running 305/30 rear tires in their GT3's. What wheel width and offset do you have? I have BBS LeMans on mine: 11" and offset is 56. I wonder if 305/30 Kumho will fit without rubbing? Rear camber is 2.4 degrees negative.
I run 295/30/18 MPSC on OEM wheels, with a 15mm spacer per side (front and rear) and that fits perfect. 305 should therefore be no problem at all. Many here drive 305
Thanks for your replies. I forgot to mention that my car is mk1 GT3. The available space inside the fender should be the same though? As the offset is 56 I still think it's going to be very tight fit. Too bad Kumho don't have 295/30 tire at all. (V70A)
I was just away for 10 days and drove it at Chuckwalla and Spring Mountain plus I have a race at Miller in 2 weeks.....my wife says I have to show up at home and at work sooner or later. Oh and it's our anniversary this weekend so the trip to TH would cost 1/2 of my net worth...tad pricey even for a weekend at TH
Yep I hear you on that with respect to the SO equation. Just dropped off my wife/daughter at the airport. They be in Shanghai for 2 weeks. I'll be at th this weekend with ncrc. I'm working but got the whole house to myself : ). So the rest of your gang will be at th? Mike
Leigh2, it was great running at Spring Mnt. with your group last weekend you guys seemed to have a great time. I was set-up next to you guys fun track layout.
