So what do we do about rear rotors?
#31
Dawg. Touché. Except I know I have 2-3 seconds to get. A/t you have reached your limit. When r u hitting Sebring next. When I burn through the 2 sets of kuhmos I'm trying the Hoosiers and I think you are toast. Have fun in Miami. Say hi to kathy.
Mike
Mike
#32
Andrew, do not argue with 911 slow.
996 gt3s are not hard on rear rotors. Even with aggressive pads!!
I bought stock rear rotors from my local dealer in 2010 at full mark-up and they were $180.00 each. If you want to call Suncoast they are most likely cheaper. Or better yet call Chuck at IM GT3 He will have the best options.
#33
#34
Peter
#35
We've already figured out that 2005 Cayenne S 350mm rotors will work on the front. Which gives us a zillion cheap options for slotted or solid rotors under $200.
Has anyone found a comparable rear rotor that will fit yet? The factory crossed drilled are cracking so fast.... Waste of money.
There has to be something that fits.
#36
I may invest in some expensive rotors for the rear. The drilled rotors out back are a waste of money. They're not super expensive at $350 a pair, but they don't last nearly as long as what you guys in the 996's are getting out of yours.
#37
Sorry to bump an old thread but has anyone found a good, cheap slotted rear rotor for ex PCCB (350mm) 6gt3? I just bought a new set of ATE Cayenne S slotted fronts that of course fit fine but now I am struggling to find a slotted set for the rear. I know 997 turbo rears will work but won't it look funky having slotted fronts and drilled rears?
#39
I get my rear rotors here: http://www.paragon-products.com/
Part numbers:
PP-996.352.405.02SEB-SL
PP-996.352.406.02SEB-SL
~$159.00 each
Part numbers:
~$159.00 each
#40
Part numbers:
~$159.00 each
Part numbers:
~$159.00 each
#42
