PFC 01,06,or 08?
#61
Sorry, but a shop that recommends the PFC01 pad for the street should have their shop shut down. That is horrible advice.
01s are extremely aggressive (and abrasive) and will NEVER get to their operating temp on street. Heck, you need several laps on track to get them up to temp. The best pad for the street is the OEM street pad.
WIth that said, the 01 is the most amazing pad I have ever used on track. If you have the right touch with the brake pedal, there is no other pad that will give that level of stopping power.
#62
I switched to PFC 08 after many years of Pagid Yellows. Here are my observations and supporting data:
PFC 08:
+ More initial bite (0.15g more braking force in the initial braking zone)
+ Consistent pedal feel from new to worn out
+ Easily able to overwhelm most R-compound tires, even a set of used Michelin slicks
- Takes a few stops to get up to temp on the street, and a few corners on the track
- Generates more heat (changed to Endless RF650 to avoid any problems)
- Hard to modulate until really hot - lots of ABS the first two track days while getting used to the initial bite
Pagid Yellow RS29:
+ Wonderful trail-braking feel, I can be very precise with the braking
+ Rarely get into ABS unless I want to; I didn't even know what Ice Mode was until I switched to PFC's
+ Lasts a long, long time, I can get a full season of tracking out of one set
- Pedal feel deteriorates as the material heat cycles; the car stops, but the pedal doesn't inspire confidence
- Requires more pedal travel to get maximum braking
In summary, I've switched to PFC 08 and won't switch back to Pagid because I love the consistent pedal feel of the PFC's. It took a good two track days to get used to the bite of the PFC's, and even now, I have to ease into the brake zones to avoid ABS. Ultimate braking power is the same for both (most likely due to the tire limiting the g forces; I get -1.1g on RA1's and >-1.3g on slicks).
PFC 08:
Pagid Yellow RS29:
#63
Definitely wouldn't run PF01s on the street. Won't get up to operating temp on the street. They will stop the car, but will be very hard on the rotors when cold. For the track, they are awesome once you get used to them.
#64
Digging up an old one as I'll need to do front pads and rotors soon.
Seems like a lot of people like to run a more aggressive compound in the rear of these cars to send the bias back a bit. My car is running a larger 350mm in the rear, which should effectively achieve the same result, no?
With this in mind would I be better off running 08 all round of still splitting the compounds. FWIW I've only done one track day and with some fairly heavy braking and ABS engagement at times I never noticed any rear end instability in the braking zones (however no idea what pads are in there currently - not likely PF).
Do PF do a 350mm rotor for the rear of our cars? I have brembo rotors but thinking about a switch to PF as they supposedly last longer.
#66
With the larger rear rotor, you could get good results running the PF08 front and rear. Lots of guys (myself included) have and do run a more aggressive pad on the rear of the 996 GT3 street and Cup cars. Works well and makes the brakes do a little more work. If want a little more out of the rears, you could run PF08 front and PF11 on the rear. The PF11 replaced the PF01 that is gradually being retired.
I ran this combo on a 996 Cup at a PCA race. Loved the braking. The car stayed flat and there it didn't upset the ABS. I think you will like it.
#67
#68
996 Cups had the same diameter rotors as the street 996 GT3. The rears were smaller. I think 330mm.
#69
I’m also wondering PFC vs Pagid (for me, 08 vs RS29). PFCs were sounding pretty tempting, but most of the threads on the subject are old and compared the 01 and 06 to the RS19, and still left some questions unanswered. And then I saw fc-racer’s post (#62, above on this page). He prefered the PFC’s but his observations make Pagids sound better to me: great control in trail braking (where everyone used to say the PFC had a huge edge), don’t take long to warm up, and generate less heat (though I'm wondering what gets hotter, as some have reported PFC transfer less heat to the calipers, brake fluid, etc.).
Anyway, the questions I’m still wondering about are:
Thanks for any insight into this!
1. Do 08s have the same issues with corrosive dust as some older PFCs?
2. How does the noise compare? (No, I won’t change pads between track days – I’ll just switch back to stock when cold weather comes.)
3. Do PFCs still have the modulation/trail-braking control advantage over the RS29s that they were said to have over the RS19s?
4. And is it correct to conclude from fc-racer’s post that the 08s would be worse on the street because they’d be hard to modulate unless very hot, and also would not bite as soon as Pagids in an emergency braking situation?
By the way, in case it makes any difference, I have a 996C2 with stock brakes.2. How does the noise compare? (No, I won’t change pads between track days – I’ll just switch back to stock when cold weather comes.)
#70
Pagid pads in my opinion don't begin to compete with PFC
01 is still kick *** today and is what I'd put on if lap time was all I cared about but they cracks rotors
06 or 08 are almost as good and easier on rotors
If 97 pads are still made they are not terrible for the street and will get the job done on track
PS This stuff isn't rocket science. Whatever pad stops your car the fastest gets the hottest so as always you pay more for a faster lap time in worn tires, cracked rotors etc...etc....
#71
08's here. I run them full time and love the stopping power. They can get squeely, especially as I come to a stop on the street, like the last 50 ft or so. Annoying! I have yet to clean the dust between pas and rotor and around calipers, that may help. All in all I prefer the 08's to the Pagids.
#72
I have RS29s in mine and still plenty of compound left but have noticed more pedal travel recently. Will be switching to 08s soon, have 01 in my Lotus which were fantastic but rotors for the Exige are not as expensive as the GT3!
#73
Basic Sponsor
PFC is not making 01 or 06 in any Porsche pad shapes. 01 compound and 06 compound came to a conclusion about 18 months ago. 08 replaced 06
and 11 compound has replaced 01.
Most DE guys prefer the 08. 08 lasts longer and gives plenty of initial bite.
Racers prefer the 11 compound. It has a little more initial bite but does not wear as long as the 08.
11 compound is what is being delivered on the 991 Cup car from the factory.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
#74
Curious who, if anyone, is running the 991 pad profile. I'm pretty sure I saw someone say it covers the street rotors fully. The standard PFC profile leaves about 1/4" of unused rotor near the hub.
#75
(I hope so, because I just ordered some Pagids. I talked to a seller who's given me good advice in the past who sells both (and who had recommended PFCs for my previous car). This time he suggested the Pagids due to noise.)
Still, they won't last forever (though probably a lot longer for me than for many of you!), so I'll face the pad choice again, and I'd still be very interested in the answers to the rest of my 4 questions from above:
