996 turboS to GT2 conversion
There is a nice opportunity to buy a an original 996 Turbo S with some work.
Thinking of what all needs to be done to the car, it might actually be interesting to to a conversion to GT2 technical Spec (as close as i can afford)
Basically i would try to make it in a 2WD car with proper race track handling.
Can you just dismount the front drive shafts and front diff and keep using the same gearbox ? Does the 996 Turbo S have a LSD for the rears that you can keep ?
Upgrading brakes, shocks, suspension arms, and front + rear spoiler was already planned.
Thanks in advance
Q&A
Thanks in advance
Q&A
i figured. Should have looked there first before posting. Sorry. You may delete this thread if you want John. so we keep it clean here till the end of the year ;-)
