Need Spring Rate Recommendations
AFTERMARKET & MOTORSPORTS HEADQUARTERS - WEST
ThyssenKrupp Bilstein of America
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
Just called and spoke to Bilstein in CA where the revalve & rebuild work gets done. They tuned me on to the download page. (link)
These are all PDFs.
Also just verified cost; $65 rebuild & revalve per shock; $75 rebuild & revalve per strut.
HTH anyone else considering.
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
These are all PDFs.
- Valving Manual - Page 1 to 10
- Valving Manual - Page 11 to 20
- Valving Manual - Page 21 to 30
- Valving Manual - Page 31 to 40
- Valving Manual - Page 41 to 50
- Valving Manual - Page 51 to 60
- Valving Manual - Page 61 to 70
- Valving Manual - Page 71 to 78
- Repair Order Instruction Sheet
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
Just called and spoke to Bilstein in CA where the revalve & rebuild work gets done. ....
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
Took about 4 weeks for mine... But winter is here anyway... I believe they have some sort of expedited service, but I'm frugal! Don't forget to request dyno sheet. Got mine afterwards via email as a PDF. Asked them to use 3200# (actual empty weight is 3167) and 38/62% f/r for valving.
VBob:
"Zero rate is the best thing to do as FFaust stated. For mostly track car with the other suspension mods, it is your best way to go."
FFaust:
"I would say 0# tenders, just to keep everything lined up when un-weighted. Otherwise, it gets too complicated for my tiny brain"
1+
FFaust:
1+
- I think you just answered your own question.
- 600/800 will be a huge improvement, especially with all the RSS stuff.
I'm currently at 620/900
- I use Swift Springs and Tenders
- 45#s in the Front
- 168#s in the Rear
I went with a sort of hybrid approach
- the 100 split crowd + the euro 700 split KW Suspension crowd
- the one thing I really like about the 900# rear spring is I feel it helps hold up the rear of the car and that helps everything
- the current KW Suspension NRing setup is 400/1100 for what it's worth
- 45#s in the Front
- 168#s in the Rear
- 45#s in the Front
- 168#s in the Rear
- 45#s in the Front
- 168#s in the Rear
My old C2 had rates of 450/900. You'd think oversteer city right? Didn't turn as well as my current setup with 600/750 on the GT3.
Some of that has to be due to valving in the shocks. The C2 had the same bilstein damper as the GT3 just revalved to H&R specs to match the springs.
I'm still not sure I've got the JRZ 3-way's totally figured out yet but they sure are nice to play with and make larger changes in the car's behavior than I thought they could / would. I sometimes think they are slowing down my learning curve with this car because I can't leave well enough alone and always want to tinker.
