996 GT2/GT3 Forum 1999-2005
Tranny is out for LSD and 1st gear syncro rebuild. G Box says needs $10K of stuff
Old 10-23-2011, 06:00 PM
  #46
CanyonBlaster
CanyonBlaster's Avatar
Originally Posted by 996FLT6
What internals for the LSD they plan to do? U should steer away from stock internals. Mike
yes, I'm pretty sure Stan is planing factory new parts except slightly uprated load springs....
what do you recommend? At this point, I'm at the end of the budget. Is there an upgrade that doesn't cost more than factory parts? Thx
Old 10-23-2011, 06:31 PM
  #47
996FLT6
996FLT6's Avatar
If money is an issue I go with cup plates- same locking ratio 40/60 as stock but will last way alot longer at minimal costs. I remember it ran $700. Stock is brass and cup are steel just FYI. Having higher preload springs then stock I would think the stock brass units won't last at all. Mike
Old 10-23-2011, 09:16 PM
  #48
P.J.S.
P.J.S.'s Avatar
he's right...
Old 10-24-2011, 11:41 AM
  #49
CanyonBlaster
OK, I'll chat with Stan.
My goal here is to not have to open the tranny again for as looooong as possible (durability), not maximum performance. What would you recommend?
Old 10-24-2011, 11:46 AM
  #50
LVDell
LVDell's Avatar
If you want the perfect balance of price, performance, and longevity you cannot go wrong with the cup gears, cup clutch packs for the LSD. I did that in mine and it was heaven.
While you are in there, you need to shorten up the gears. The current structure is one that will never be exploited. Bring the top end down in the 170's and shorten gears 3-6. Depending on what track(s) you predominately run, talk to the shop building the box and tell them what stock gear ratios are like on track. The options are virtually endless to get that "perfect" gear set.
Old 10-24-2011, 12:43 PM
  #51
996FLT6
996FLT6's Avatar
Stock durability- terrible(brass units will just wear faster- why they put that junk in I don't know why). Cup durability-U get in spades : ). Mike ps- like Dell mentioned I woulda done the whole tamale except add a shorter r/p and gearsets he mentioned because I'm a track junkie : ). Mike
Old 10-24-2011, 01:07 PM
  #52
AllanJ
AllanJ's Avatar
As per Matt's previous post elsewhere on this site, don't go too short on 3rd if durability is important. Keep 3rd gear in the 1.600:1 to 1.650:1 range. Avoid 1.684:1 to 1.789:1 area because they have a shorter lifespan that you may not want due to their physical size.
Cheers,
Old 10-24-2011, 03:46 PM
  #53
GTgears
GTgears's Avatar
Ring and pinion and a mainshaft? Yeah, it's feasible to hit $10K with that kind of damage. It's not that common but some of those pinion bearings have been known to fail prematurely on these boxes.
Stan is no idiot. He won't stack your LSD too tight. If he gets you the Cup Car vane kit, he can adjust things appropriately to give you a good street/DE diff and not build you something that's race spec on your driver...
Old 10-24-2011, 04:46 PM
  #54
P.J.S.
P.J.S.'s Avatar
Maybe this helps
http://www.pelicanparts.com/cgi-bin/...20AND%20PINION
That is retail
Old 10-24-2011, 05:24 PM
  #55
cfjan
cfjan's Avatar
The 7.2RS ring 'n pinion set might be a good choice for someone who does not want to go as aggressive as the Cup or the Guard setup.. (and still offer some reduction in ratio)
Old 10-24-2011, 07:26 PM
  #56
FFaust
FFaust's Avatar
And that's why you need to do it right the first time...
... but it seems as though you are in good hands
Old 10-24-2011, 11:59 PM
  #57
GTgears
GTgears's Avatar
Gbox may not be an authorized Guard Transmission installer, but Stan is a more than competent mechanic with several decades of gearbox expertise.
Old 10-25-2011, 01:06 AM
  #58
jrgordonsenior
jrgordonsenior's Avatar
Damn big of you Matt.....
Old 10-25-2011, 01:33 AM
  #59
Turn3 Autosport
Former Vendor
Turn3 Autosport's Avatar
Nice avatar Matt, cars looked good on the weekend and will look good at Daytona!!
Old 10-25-2011, 02:34 AM
  #60
996FLT6
996FLT6's Avatar
"......"? Mike
Quick Reply: Tranny is out for LSD and 1st gear syncro rebuild. G Box says needs $10K of stuff
