LSD Shot?
#31
#32
I dare to say my OEM LSD is still working reasonably ok after 45K street miles and 10K track miles (those are mine). When i park my car in reverse, and in need of a full lock turn, my LSD still stutters, bounces and makes noise like a 1940 ***** Jeep.
And the final, only way, to really test (measure) it, is with a torque wrench (taking the drive shafts off)
Prior to taking it out for repair, you should do this anyway to be even more sure. I also did that 5000 miles ago and it was still within Porsche's tolerances proving that not all LSD's are being shot after 16K miles ;-)
When driving up som very steep, thight hairpin turns (12-15% uphill 180 degree turns) the inner rear wheel lifted clean off the road for a long time in every turn. When the wheel was in the air I had no traction out of the turn, and when it finally came down the car shot foreward leaving a singel stripe of rubber marks after the inner wheel was finally gripping. This happened in several turns, going both right and left.
#34
It's a major PIA, but doable. With a lift, easier on the upper body (I would imagine). Pulling the L axle, easier still. Not complicated at all, just difficult to access and work around hoses, axle, etc.
#35
Also, I'd use the factory technique as the only test. Slight tail wagging on hard braking does not in an of itself indicate a screwed diff. From Post #1; "Very unstable", is tough to quantify. GL
