ambition exceeded talent -- roll bar question
Too much speed into Turn 1 at Harris Hill taught me a couple lessons:
1a. Slow down.
1b. Push the clutch in before going backwards.
2. It's time to replace the BK harness bar with roll-over protection.
From previous searches, I think I'd like a GMG bolt-in product (over Tek or DAS). Within the GMG catalog:
At 6'5", I have the driver's GT3 euro seat bolted directly to the floor as far back as possible with some slim BK mounts (no sliders). I'm guessing/hoping that the GMG solutions will accommodate. What, if any, are the downsides of using all 6 anchor points with the combined WC+reinforcement? Similarly, why go with the RSR over the other combo? The car is only a street car when it drives to and from the track. I know many members like TC Designs, but unless someone has one just sitting in their garage ready to ship, I don't see this as a doable solution for me.
Thanks for the help.
1a. Slow down.
I would be really interested to see some clear images of how you bolted your seats directly to your floor.
Did it help you ? I looked at the option of lowering the seat within the sliders (drill some extra holes) but i see not even 1 inch of extra room.
Might do the same. I also struggle with my length (6"1) trying to heal-toe without bumping against the steering wheel.
Already took my bottom seat padding out, and removed the floor carpet and are also still looking for a good hub.
Mike -- regarding the DAS, I don't have a great reason. When I got the car a couple years ago I did lots of searching here and what I remember most was GMG mentioning tall-friendly features. Then after getting a new diff, new tires, suspension corner-balanced, RS wing, etc, the bank account decided to run the BK harness bar that came with the car. Didn't really think about it again until recently... If a used DAS bar comes up I wouldn't turn my nose up at it.
I'm 6'4" and was a little nervous about doing the rollbar/seat thing, as not many people/shops have "examples" to demo before buying. The car had the Euro GT3 seats already installed with sliders and I did not have sufficient head-room for a helmet.
I bought the BK lowering mounts that attach to the sliders - I still wanted to have the sliders so my wife could drive the car if she wanted and I have a different seating position for street driving (what little I do drive on the street) than on track. I figured if it still didn't work I could just fab a plate for the floor and bolt the mounts to that. The mounts workd well, gave me the necessary drop (even better with the cushion removed) and some very much needed recline - I find that I don't need to put the wheel closer to me.
For the rollbar, I made several calls and searched and searched. Availability, cost, and design features led me to the RSS 930 bar. It mounts to the seatbelt attachment points on the B-pillar at the strut-tops and has the harnesses attach behind the seat. Funny, I find that I don't really change the location of the seat, so I didn't need the slider, as the one position it's in is good for both environments...and my wife is afraid to drive the car, so no need for that. With the seat in a far-back position, I've still a few inches of rearward travel before the bar comes into play...there is ample room, for me, with this bar. The harness angle with the Euro seats and BK mounts also have a proper angle of the harness, which was another concern for me.
All in, I'd do it again if I had to. I'm sure the GMG bar is top notch, too.
Good luck with it,
TomK
Good luck with it,
TomK
TomK, thanks for pointing out the RSS option, I was unaware of those. They look nice, designed/built in-house, and reasonable cost. Since the 930 bar doesn't appear to be different for sunroof or non-sunroof cars, can you tell me if there's a gap between the top of your bar and the headliner? When ordering the GMG bar, they ask to specify with or without sunroof, so I assume GMG's non-sunroof option may give a little more room. Even if there is, $1K for 1" (or less) is pretty expensive.
Absolutely, if that option is there. GMG and DAS both look to have two versions of their bars, but RSS appears to only have one bar. Love the new avatar.
Since seeing 24chromium/crazy Canuck and mr moderator 911 slow avatars- WAR IS ON : )!!!!!. You should email rss if that one size fits all is possibly just meant for non sunroof cars. 997.1 gt3 is the only one with sunroof unless it's designed for all modern 911's. Mike
Just measured from the back of the bar to the headliner- 2" from the headliner. The bar sits behind the b-pillar, so unless your head detaches from your body, it should never hit it.
The other thing I liked about the RSS is that the "bolt-on" part is right at the strut-towers, not by the main hoop joints...fwiw.
Any of the bars mentioned are all good choices, not a bad one amongst them.
Good luck,
TomK
Good luck,
TomK
