996 GT2/GT3 Forum 1999-2005
Rebuilding the LSD
Old 06-07-2011, 10:27 PM
Dudley
Dudley's Avatar
Default Rebuilding the LSD
My LSD has finally passed on and I hope to send it out to Guard for a rebuild.
I say hope since I cannot figure out how to get the LSD passed the drive shaft.
Is there a trick to this that I can't figure out?
If you have solved this puzzle, I would appreciate your help.
TIA
Old 06-07-2011, 10:30 PM
SpeedGT3
SpeedGT3's Avatar
Maybe remove the axle entirely, or drop it lower?
Old 06-07-2011, 10:32 PM
996FLT6
996FLT6's Avatar
Pm Mikymu - he should answer your question : ). There's a DIY on 997 gt3 board- do a search. Mike
Old 06-07-2011, 10:48 PM
enthusiast
enthusiast's Avatar
+1 on looking at the Do It Yourself.
Old 06-07-2011, 10:57 PM
SpeedGT3
SpeedGT3's Avatar
Try this link
https://rennlist.com/forums/showthre...ferrerid=15725
Old 06-07-2011, 11:02 PM
Ken89911T
Ken89911T's Avatar
Push the hoses up, push the axle back and down/up, then wriggle the LSD out with your other hands. It's a bitch, but can be done, forcibly but with care not to rough up the casing. Getting it back in is even a bit harder.
Old 06-07-2011, 11:28 PM
Serge944
Serge944's Avatar
Removing the axle ahead of time makes the job a lot easier. Or...taking the whole engine/trans out! I just rebuilt mine with Guard parts as I type.
Old 06-07-2011, 11:38 PM
FFaust
FFaust's Avatar
Looked a lot easier on the LSD Buster thread
Old 06-08-2011, 02:49 AM
MTB
MTB's Avatar
+1. Take extra 15 min to remove the axle and make the LSD in/out a lot easier.
Old 06-08-2011, 07:12 AM
Dudley
Dudley's Avatar
+1
Thanks guys. Maybe removing the rear axle is the way to go.
Old 06-08-2011, 10:07 AM
Dudley
Dudley's Avatar
Oh, I found a great test for the proper function of the LSD. There is a tight turn #3 at NHIS. If you take it in 2nd gear going up the hill after the turn, the driven wheel loses traction. It will feel like you lifted the throttle midway through the turn as you spin of the track. I took the turn in third for the rest of the weekend, feathering the throttle. Still I had to catch her on nearly every run.
Old 06-08-2011, 10:39 AM
Dudley
Dudley's Avatar
Success!! A buddy came over and I held the drive shaft up while he wrestled it out. We also loosened the stiffener for just a little more room.
I am going to leave the ring gear on and ship it to Guard.
Old 06-08-2011, 10:51 AM
cfjan
cfjan's Avatar
Dave, so is it a fairly reasonable job for a DIYer? I mean, I have seen the LSD Buster thread, but just want to hear another opinion..
Old 06-08-2011, 11:58 AM
Dudley
Dudley's Avatar
Reasonable? Yes. I give it a seven out of ten in difficulty. I am no mechanic by anyone's definition but I managed it. I also have a scissor lift in my garage that helps.
Mikymu's DIY is very good. Only subtle differences with our car. The axle flange bolts are hex head rather than torx.
Old 06-08-2011, 12:04 PM
cfjan
cfjan's Avatar
Nice.. yeah, no lift here.. if I am doing it, I'd have to use jack stands or some wood block under wheels...
Quick Reply: Rebuilding the LSD
