380mm rotors on a 996GT2
Hi Guys I wonder if anyone knows about a spacer or bracket to use 380mm rotors on the 996GT2.
I know that I would need a 15mm spacer, but I just need it asap, as I have to replace my rotors for the next event, next week.
tks
tks
From what I know, the 996 caliper will take 997 pads which leads me to believe that the calipers are essentially the same. Most likely you will need the mounting hardware from a 997 Turbo or GT3 (Steel brake version) to mount these with your existing factory caliper. I would look into that. The brake line lengths might also be different (You might need 997 ones, but I am unsure).
thank you,
Looks like I have different up rights in my car, by the invoice it says that I have 996 gt3 RS, which are the same as the firsts cup cars out there. So in order to use the 997 gt3 or turbo PCCB mounting hardware I believe that I would need to have their up rights. Is that correct ?
