Sway bar link nuts only "hand tight"
Did I hear duct tape?
http://www.oddee.com/item_96822.aspx
http://thezac.com/ducttape/
http://www.octanecreative.com/ductta...ten/index.html
There's even a duct tape nation forum.
http://www.ducttapenation.net/index....ic=112.msg355/
Wow, I could go on all day. Had no idea.
GT3 player par excellence
I just replaced both my sway bar nuts during my toe link replacement. I applied blue locktite plus lock washer on each side. I never realized that the sway bar link has an opposing nut next to the inside of the swaybar. I am thinking that this is possibly why they come loose because if you tighten the outer nut and not hold the inner nut you may just be turning the stud and not properly securing. I have never seen anyone mention this.
You all are over engineering this problem. Loctite is not needed or wanted. Get a 10mm nut and lock washer and apply to drop link. I have used this system for over 25,000 miles and never had 1 come loose. I can reach under the car with out jacking or putting on blocks and change the setting in less than 60 secs per side. Works real nice for a quick easy change @ AutoX depending on surface and then change back to a less aggressive setting for the street or track
Peter
Peter
Peter
Peter
OK, I poked my head in there and I can indeed see the drop link connection to the sway bar. Looks like the 2010 GT3 uses a 16 mm nut? Of course I've only got odd sizes in my tool box, so it's off to the store for me.
Anyone know what the torque is for the 2010 model?
