Why is the cup shifter so much better?
#31
What I tried was like a rifle bolt. Solid. Crisp. Purposeful. It felt extremely good and I was sold right away. I asked about the shifter and they are the ones that told me I don't need it. After that demo, I can see why.
#34
Rather than stock shifter I'd recommend the 997 gt3 shifter. Has a better cable path and more robust. When mated to cup cables it's lovely. Cup shifter may of course be more robust, but not sure it's worth it...
#35
Dan, Did you have the cup shifter assembly and cup cables, initially?
I was wondering if you could offer a comparison of noise levels experienced with each mod.
#36
Admin
Had both the 997.1 GT3 shifter and the cup shifter.
The 997.1 GT3 (*same like regular 997s btw) is better than the oem 996gt3 shifter (has a metal plate on the side) and shorter.
But the cup one is in another Legue IMO. They are made for each other and most importantly its a race proven part; what more to say?
But it is not as short as the 997gt3 and indeed it brings more vibration inside due to luck of dampening from plastic and rubber missing on the vertical axle.
ps my car vibrates anyway so I don't mind
#38
Admin
^ Yes that's why I said they are made for each other.. cup shifter+cup cables.
I did 997.1gt3 shifter first with oem cables
then added cup cables
then cup shifter..
then cup shifter..
