GT3 Cup gear change cables for a GT3
#32
Hey, just curious...maybe a stupid question...can you run a cup shifter and standard GT3 cables? Wondering if the cup shifter even fits inside the center console...
Also, where does that 'superb experience' come from...is it more the cup shifter or the cup cables?
TIA
TIA
#34
And compared 997 shifter vs 996 cup shifter it's cup shifter is 10% better. It's feels way mated to cup cables even though throws slightly longer. Mike
#36
Admin
Hi Mooty,
I have a 2004 gt3 just did cup cables and 997gt3 shifter, already running lwf, stoked on the shifts and some of the whining noises, but the growling gets a little old, was thinking about ways to subdue this, any ideas? I think you know Todd from Arizona, was wanting to buy his car awhile back but I heard it got wrapped
Some people can't live with it.. others love it.
The cup shifter alone will add almost nothing, the cables alone are a big improvement.
But the thing is that they are designed to work together, an excellent race proven setup.
Make sure to upgrade all the necessary parts.
https://rennlist.com/forums/8118556-post21.html
#37
This season my Cup shifter is just a bit stiffer than last fall. I realigned the shifter console but the throws were so much slicker when first installed.
I greased the console and that helped but not perfect. I think my shift cables might need lubrication. I have been caught in the rain at the track a few times. One of the cables has no rubber boot, this could be the issue.
How do I clean/lube these cables? I have a cable lube attachment left over from my motorcycle days but it is not nearly big enough to fit the cup cables.
Does anyone lube these?
