More Track Prep
Just for good measure mostly, and future growth/flexibility. Some posts here suggested longer ones in the rear. With the dizzing array of widths, offsets, wheels depths, etc.etc. I wanted to make sure I would have enough nut thread engagement....
Got to love Girodisc and the Rennstore service. I noticed the box on your FS post and was wondering when you'd post something like this. The quality is first class.
Is there a benefit to studs rather than bolts? Speed of change?
Scott, first of all thank you for your purchase.
I wanted to post a better link to installation instructions for those who are looking to do a stud/nut conversion.
There is a PDF linked here also if you want to print out some instructions.
http://www.apexcompetition.com/Produ...ud_install.cfm
A couple of other notes about out products.. we have 3 new designs coming out very soon specifically for Boxster, Cayman and GT3 etc. These 3 should cover most wheel / spacer / car combos.
![](http://www.apexcompetition.com/ProductInfo/images/DSC_0564.jpg)
Also, please make sure that you never use an acid based based wheel cleaner on our products! This stuff is caustic (obviously) and while it does a good job at removing caked on brake dust, it also attacks coated steel quite well. We've used "Simple Green" (like many of you) on our street 996 which has a set of both our performance studs up front and our "race" studs in back... and it's going on 3 years now with no significant corrosion.
Lastly, an important safety note. Many other retailers are selling "ball seat" Nuts for Porsche. But what does this mean? Ask them if they are R12, R13 or R14 radius nuts, you'll most likely draw a blank stare. M14x1.5 VW/Audi nuts are commonly sold as "ball seat" nuts for Porsche.... yet they will NOT seat properly on an OE Porsche wheel !
See this photo.
![](http://www.apexcompetition.com/ProductInfo/images/M13_Radius.jpg)
Notice the tiny band where it contacted the wheel seat? This was the only area of the nut that was contacting the wheel because VW/Audi nuts use a different radius. So don't bolt on those Mercedes, Honda or VW/Audi ball seat wheel nuts when what you need are PORSCHE specific wheel nuts!
OK well I have hijacked enough of your thread Scott. Apologies for that!![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
PS - Beautiful car BTW.
See this photo.
GT3 player par excellence
You would need the R14 (ø28) Porsche seat nuts if you run OE style wheels.
Yellow Zinc is all we have now. Black Oxide coming soon. Copper coated coming this fall. Remember if you have aftermarket wheels, you may require taper seat nuts instead.
Holy Museum Piece, Scott! That car is lookin' hella clean!
You better start shopping cup cars before you start ripping out the interior, regearing the box, and redoing the dampers...
