Tire Clearance Help!
I'll definitely move to the 235/40 next time as it's 10mm narrower and .1" shorter diameter. The 245 worked fine with the GT3 but then again the front on my GT3 was coilover based instead of the monster shelf to that holds the spring in the X73.
Here is some inspiration of what a turbo can do (you'll have to get half way in, the camera car is a supercharged honda Exige mk1 which is quicker than any GT3):
http://www.vimeo.com/11578403
My bad, those smoked side marker lights easily add 5hp!
In all seriousness, I haven't touched the car enginewise like most Turbo guys so the power is totally stock. Haven't changed any suspension bits except for the OEM sport shocks. Other than that, full rubber based suspension and heavy as a ****!
And I don't plan to do ANYTHING to the DME power mapping of this sucker until the factory warranty expires in 2 years. Then.........ALL BETS ARE OFF!!!!!
