Disconnecting battery problems
Cruisin'
Does anyone know how to disable the alarm so I can disconnect the battery to take it out to charge (on a 996GT3RS?)
Everytime i undo the battery terminals the alarm goes off?
Maybe I'm not interpreting this right- u say as soon as u take teminals off from
battery the alarm sounds(if stock no way it'll trigger alarm- there's
no power after taking out battery) If u don't have an extra battery or like above said an aftermarket alarm system with dedicated battery- it ain't going to happen. If aftermarket find the battery and disconnect the line to it. Also why not
run a trickle charger via cig liter wo charging battery unless car is in a parking lot. Mike
Cruisin'
Is there a battery backup for the alarm? maybe thats setting it off?
I cant run a trickle charger as there are no power sockets in the parking area
Tracker is probably the source of another battery. I have a quick disconnect on my battery and I pull the key off all the time and it never triggers the alarm. Mike
I never put key into ignition when I disconnect battery and it never triggers the alarm. I believe your tracker has a battery source that's tied to the alarm in case someone wants to cut the power off so alarm won't go off and they can tow/steal your car. Mike
Hmm, not sure why a 6GT3 would need an alarm, let alone after market.
At the track my key was always sitting in the console.
Unless this is a D.D for you and you park on the street, who's going to take it, unless it is another guy at the track?
(a slower guy, a guy you made look silly for bringing a British car that broke down 3 laps in).
It is all coming together now!!!!!!!!!!!!!!!!!
Ditch the alarm and use a float charger for long term storage.
Before removing the battery put the key in the ignition, turn on ignition, leave the ignition on while removing battery terminal.
