Lug nut question...
I had the same issue with the lugs bolt head sticking out when I put them on the BBS rims. Is there a solution where I can get some lugs with smaller bolt head?
Backmarker- thanks. As it turns out, there was no issue and I ran the car at the track this weekend w/o incident. I will probably switch to open lugs in the near future.
Measure the thickness of the new wheels from the ball seat to the rear face of the wheel. Compare it to the length of your lugs and you will know for sure if you have enough threads to keep the wheels on.
You can also search on here and see if people with the same wheels have to go to longer studs. BBS's for example require a much longer stud than stock.
I have a set of the Kinesis K28s I would like to sell if any of you guys know anybody looking for a set. Shoot me a PM for pictures and info.
