SharkWerks 996 GT3 Project Car Build
#61
Alex,
Do you expect the 3.9 treatment to go pretty much the same as the 997 GT3? (since you mentioned the engine are very similar) Or there will be things that need to be done differently??
Different cam?
Different cam?
#62
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Thanks Michael... we also sort of opened a can of worms and possibilities when we split the case
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#64
#65
We're just uprgading it with our rebuild kit. Because the 996 already has 40/60 ramps and good spider gears in it, there's no reason to go any further, even for the power levels they are making. But having an LSD in there that actually locks is going to let this car put all that extra power to the ground. They've just got to make sure their tires are sticky enough.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#66
Hello I am following this post, congratulations. I have a 996 Carrera 2 2003, and I want to mount the throttle body that I bought the GT3. Now I need to mount a new plenum. The original of the 996 GT3 plenum I see in this post, which has diameter in the two late? The outer diameter of the plenum to the sides where the sleeves and rubber 'of 97 mm? While in front of where the throttle body and the inner diameter 'of 83 mm, with a distance of 4 holes of 75 mm? Thank you.
#68
We're just uprgading it with our rebuild kit. Because the 996 already has 40/60 ramps and good spider gears in it, there's no reason to go any further, even for the power levels they are making. But having an LSD in there that actually locks is going to let this car put all that extra power to the ground. They've just got to make sure their tires are sticky enough. ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Next step is assembly, break-in and then we'll get together with EVOMS to do the live tuning. So absolutely
#69
Absolutely love this thread. Great to see in detail the (re)build process, including differences/similarities between the 996 & 997 GT3 engines. Keep up the good work SharkWerks!
#70
After looking at this <https://rennlist.com/forums/997-gt2-gt3-forum/569382-nip-tuck.html> thread on the Akrapovic 997 GT3 exhaust, I wonder if the headers+mufflers would fit on my 996 GT3, needing only a short pipe from the muffler to the bumper cutouts. Light weight and good sound? Alex, are you interested in trying this combo on your 996 GT3 and helping us all out? Thanks for the great thread.
#71
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#73
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![](http://gamingbolt.com/wp-content/uploads/popcorn.jpg)
Cool avatar!
#74
Back over to assembly now...
In goes the crank, GT3R oil pump, all new bearings and of course the Ti rods....
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly.JPG)
The EVOMS head stud kit installed:
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_10.JPG)
There was an short break as we moved over to the new shop and James' new engine room. In go the Sharkwerks big bore pistons/liners:
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_11.JPG)
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_13.JPG)
Coming together... and the block starts to grow:
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_16.JPG)
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_20.JPG)
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_22.JPG)
Now we get to the all-important cam shafts:
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_31.JPG)
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_29.JPG)
Timing the cams (these require different timing blocks from from the 997GT3):
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_39.JPG)
![](http://videos.g33kd.net/996/carrera/Porsche_2004_996_GT3_SharkWerks_Project_Build/engine_reassemble/SharkWerks_Porsche_996_GT3_project_build_engine_reassembly_40.JPG)
More to follow shortly but we're getting closer...
