pimp my interior
Has anyone installed a modern nav + bluetooth + iphone head unit in their GT3?
Also, who has carbon inside? GT3'er did you install the horseshoe yet?
I'm interested in pictures, what you put in and what it cost, it's been a while since we had a good pics thread
believe it or not I have an aftermarket head unit because i used to drive to the track the stock system almost made me stick a pencil through my ears. I never removed it...but in a gutted car the cabin can ring like a bell with certain frequencies. If you have carpet you're fine.
I went with alpine with an ipod connector and separate a 80w 2 lb(!) amp. I also have 2 way light weight focal speakers (audiophile) in the stock f/r locations and a removable sub in the passenger foot well. With the sub removed the whole system weigs about 10lbs.
You can get a flip up unit that has a touch screen with Nav and all the goodies that fits in the stock place.
As far as the carbon, theres an OE replacement.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Here is a copy of the order guide, standard equipment. It says radio, I still can't find it in the car.
911 GT3
$99,900
Standard equipment includes:
3.6 Liter 6 cylinder engine producing 380 Horsepower.
Dry sump oil system with engine mounted oil tank and dual oil pumps in the crankcase.
Dual 3-way catalytic converters.
Two stage resonance intake system.
Titanium connecting rods.
6-speed manual transmission with double inertia flywheel.
Limited slip differential.
Transmission oil cooler with supplemental radiator.
Rear wheel drive.
Pressure cast 18” GT3 Wheels (Monobloc)
McPherson front axle with special spring and shock absorber set up.
Multi-link rear axle with rigid axle and special spring and shock absorber set up.
Adjustable suspension with red painted suspension springs.
Aerodynamics package including modified front bumper cover, fixed wing rear spoiler
and flared rocker panels.
Rear hood with “GT3” in black.
6 Piston Aluminum Monobloc Red front brake calipers with vented/perforated brakes.
4 Piston Aluminum Monobloc Red rear brake calipers with vented/perforated brakes.
Two leather sport seats. No rear seats.
CD Radio with Anti-Theft Coding (Porsche CDR 23).
Central locking with remote control and alarm.
4 Position Manual Ventilation Control without Air Conditioning.
Full Climate Control with Air Conditioning (No Charge Option ‘573’ must
be specified)
** Some elements of the Interior Diagram are European Spec and
May not be available in North America**
Porsche Cars North America
United States Order Guide
Model Year 2005
Option prices, content, availability and relationships are subject to
change without notice.
911 GT3
$99,900
Rear wheel drive.
be specified)
Model Year 2005
so you have the A/C Delete AND the Climiate Control A/C package?!?
be specified)
be specified)
Fun thread. No, I haven't installed the whoreshoe or the gauge surround. Need to find some instructions so I don't break anything taking it apart. And then there's the issue of finding time...still have the console delete and the 997 shifter cluttering the work bench...I need a vacation...
