ATE Cayenne rotors for GT3
#64
Bah! It's cast iron....very soft. I just drilled a hole with a countersink in under a minute with a cordless drill in one of my old cup rotors.
A simple locating jig would make drilling one hole super easy. That's all you need to use one screw to hold the rotor in place. I don't see any stress on that little hole causing cracks either (unlike like the holes in the swept surface of the rotors).
YMMV, do this at your own risk, blah, blah, blah....![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Cheers,
Cheers,
#66
Once the caliper is back on the rotor is rock solid. As I mentioned in my previous post, if you look at the philips screws you can see from their small size that they likely contribute fairly little in keeping the rotor in place. I've put two hard braking track days on them in Monticello plus the fellow who placed his 996 Cup car in first in a couple of the Watkins Glen club races few weekends ago using these rotors - no issues.
#67
Ok go ahead and laugh but what size rotors do we have 330 or 350mm? I am pretty sure 350 just want to confirm before I order. Do I need any other parts to do this? Seems like a pretty straight forward change.
All this talk just made me go look at mine and I have cracks! headed to DE this comming weekend and need to order asap. Who can get them the quickest?
Stealer quoted me $1200 for installed stock!
#68
The ATE Cayenne are the correct size - Part # 24.1334-7123.1. I *think* they are 350 but the box doesn't say. TRUST ME! They are correct.
Installation requires no special tools or knowledge. 68 ft-lbs torque on the caliper bolt, IMO, btw.
#69
Peter
#70
#71
Can't see it mattering. It's ~1/4" hole with a slight countersink and it's close to the center of the rotor. Not enough mass removal to make an impact. More tire "goo" will be distributed unevenly around the tire at your first DE and would have far more of an impact than this.
IMHO of course.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I ordered a set of these ATE rotors and will be installing them probably in late July. fwiw, I don't plan on drilling a mounting hole unless the installation is a pita without them. From what I read above I think I'll be fine though.
Cheers,
IMHO of course.
Cheers,
#72
#74
Former Vendor
As a complete and total aside, I've *1* set of DeMan rotors ready to ship, discounted $100.... from $695 to $595...lowest ever.
1 set, first come, first get - e-mail rennstore@comcast.net
#75
