996 gt3 camber opinions
I am running Pirelli P-zero Corsa's. It is A DOT rated Comp. Tire w/ UTQG of 60. My target hot pressure is 35-36 psi. . I expect to start at about 27-28 cold. I will experiment from there.
I personally don't use the corsas but i have used their slicks. so i can't comment on your pressures.
Start with your sways where they are and experiment. I suggest you use new tires to dial your car in.
for me, I track at mostly two tracks, so I was able to dial in a good alignment for my GT3. I had to use a Pryometer or thermal gauge to see get the heat across the entire tire as much as possible when I came off the track hot. I have a -2 on the rears and -3 up front. it will differ for each car, the track, tires and driving style, etc. but your tire wear will change with each tire manufacture and type, not to mention any bumps you hit and you start all over.
not to mention any bumps you hit and you start all over.![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Seriously if i thought about a bump hard enough the rear toe would go. Happened at WSIR at 145, saw my life flash before me as the car snapped around. luckily i caught it, came into the pits and changed my shorts
Still plays with cars.
Your pressures for the Corsa are spot on. On my 6GT3 I found F R hot to be the sweet spot.
I would not worry about the increased camber. Yes your tires will wear out fast on the street. On the other hand with the Kussmaul (by the way I was the one who got them and posted them here) settings, your tires will also wear out fast on the street. Chances are you will wear out your tires on the track first though so I wouldn't worry about it at all. Your toe settings are correct but you really want the rear toe links because the OEM set up is very fragile. I used the Corsas a lot on my 6GT2 and 3. About 1 second a lap slower than the Michelin cup on a 1:50 lap. The advantage is that they can be street driven and unless very worn, you are not SOL if it rains. So you trade off a bit of 'stick' for versatility. The Corsa is back in production and I will be using them myself this summer.
Best,
Best,
Bob,
Thanks for the info on the Corsa's and settings. Are you going the get the "system" or run the same tire F & R.? Are you using 35 hot for both F & R?
I have used the mpsc on other cars with good results but I couldn't find them in the proper size/load rating for this car. BTW Michelin customer service beats Pirelli by a lonshot so far IMO. With mpsc on other cars driven hard I was gettibg +8-10psi cold to hot pressure which is about right.
I think I will start at about 28 cold and go from there as the car is new to me and I will be taking it easy at first (I think!).
-Regards
-Regards
I run mpsc at 31 hot all around. If tire pressures above 34 maybe it's my driving I slide alot. With reference to street cars tire pressures is what your comfortable with. 34-36 hot-good starting point then go lower : ).
Mike
Mike
Mike
Mike
I do 20+ track days a year. I have not done any other suspension pieces yet. My concern is the additional camber affecting tire wear during street use, although limited. I have rotated the struts to allow for the additional camber. I am just trying to get a baseline to work from. Since the tires are not a full racing slick, I was debating whether almost -3deg front would be too much.
My car came 'dialed in' and eats rear tires on the street (to and from the track).
I've decided that after 15 years of track day fun I'm old enough to buy a pyrometer and eliminate the guesswork- too much camber or is it actually helping on track?
Backmarker,
Do you know what your suspension settings are? There will always be a compromise if the car is driven on both street and track IMO. I think a pyrometer is a good idea if you want to get serious about testing.
In agreement with an above post, in the past I have always worn out the tires on the track before street issues came into play. Since the tires are not full slicks on my car, that is they have some tread, I don't know for sure if a pyrometer is as effective. I use hot pressures as a guide and sometimes an IR pyro to get relative temps across the tire. Although not as reliabe as a probe, I feel better about not poking my tires with a needle and the IR also works for track temps, rotors, calipers, etc..
would like to chime in something here... for whatever it's worth... i just got the car back from my alignment shop and they told me the rear alignment was spot on from 1 yr ago. they didnt have to adjust anything after 1 yr. suspension is completely stock incl the rear toe links, about 8 track days and 2k street miles for a total of around 3k miles since the last alignment.
maybe i just dont drive it enough
maybe i just dont drive it enough![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
